Digital Joint Maker Gadget 3.0
sharkcutup
Post by sharkcutup »
Hello Everyone,
In Memory of Jim Anderson
Here is the Long Awaited Digital Joint Maker Gadget which he helped me to create ---
The Digital Joint Maker Gadget contains a Total of Twenty-Five (25) Joint Styles. All Gadget Joints have been created as Single-Sided Carvings. Each Gadget Joint will vary is size due to their Individual Style Type. Each Gadget Joint that is selected will have to be Removed from their Perspective Counterparts, Scaled and Attached to their New Counterparts for usage. Then either New Toolpaths will have to be Created or the Original Toolpaths will have to be Re-calculated. All Gadget Joint Vectors are Identified and Created on their Perspective Layers. The Actual Usage of a Particular Joint is up to the User's Preference and their own Knowledge as to how each Joint is to be used within their Particular Job.
Comments and Suggestions are always Welcomed!
Item Changed/Added: NONE
1.) Initial Release Version 3.0
https://www.dropbox.com/scl/fi/he1hjcmj ... zuwcy&dl=0
File Was TOO LARGE even zipped to attach here!
Current Version: 3.0
Supports: 12.0 versions of V-Carve Pro, and Aspire --- Not sure about any of the other previous Vectric Versions
Installation Instructions:
1. Download the gadget Digital Joint Maker_Ver_3.0.vgadget from My Dropbox to a File Folder on your Computer.
2. In Vectric Pro or Aspire click on Gadgets -> Install New Gadget and navigate to where you downloaded the above noted file to select it and click Ok.
It should give you a pop up saying the gadget was installed and you should see Digital Joint Maker_Ver_3.0 in the Gadgets Menu. After Installing Close Software Program then Restart Software Program to complete the install for using Gadget.
Next up ---
Continue to monitor gadget and possibly add more Digital Joints, etc…
If you find an issue with any portion of the gadget, please let me know. I will do what I can to fix it within hours not days and/or weeks. On Rare Occasions a complex issue may take a bit longer to resolve. Also I am rather New to the LUA Coding so it may take me a bit to solve an issue.
Thank You All for your Interest and Support of the Gadgets!
God Bless Jim Anderson and His Family!
Merry Christmas Everyone!
Sharkcutup
V-Carve Pro 12.013
Bobtail Farm
Post by Bobtail Farm »
Thank you.
