Vic's Top Tip
You can "add side" to the toolpath name when saving out toolpaths in a two sided job.
This option automatically adds the side name to the toolpath name as it's saved...
Helping you keep your toolpaths organized!
V12 Project - Fun with Flutes
When you think of flutes you most likely will think of architectural pillars or columns. In the past we have shown you how to use flutes on a rotary project, to add decorative details to toys and even how to make a stool seat. In this free project Todd will take it even further and make a fun marble run game!
To start off Todd will review all the options available in the Fluting Toolpath. Then using a gadget available for Cut2D Pro, VCarve Pro and Aspire he will create a basic spiral. Using that spiral in VCarve Desktop he will show you how to make a four part marble run game. The final project only contains flutes, pockets and profiles and cuts in no time so you can get right to playing with family or friends.
WATCH & DOWNLOAD https://www.vectric.com/vectric-communi ... marble-run
Hack of The Week No.273
BUY NOW https://store.designandmake.com/shop/product/22003
Maker Spotlight - Compass Breakfast Table By H Kellins
“I just completed this 45-inch diameter breakfast table featuring a detailed compass design crafted from maple and walnut, framed by rich mahogany, with a striking wenge border around the edge. The piece is finished with Rubio Monocoat and topped with a Nano3 protective coat for enhanced durability and luster."
“This project has been the most complex and challenging work, requiring two months of dedicated effort. The production involved a blend of techniques: about half was completed with CNC for the more complex curves in the wenge border, while the rest relied on traditional table saw work and extensive hand sanding.”
SEE MORE INSPIRATION viewtopic.php?p=322187#p322187
Faux Door Knockers Models OUT NOW!
View Models https://store.designandmake.com/search/ ... reatedDesc
Vectric UGM Bundle Now Available https://ugm.vectric.com/purchase
EasyCarve COMING SOON.... https://easycarve.com/
Vectric Make Off - Holidays From Around The World
Santa's Magic Key - OUT NOW https://www.vectric.com/vectric-communi ... -magic-key
Holiday Serving Tray Coming 26th November
Light Up Santa Coming 27th November
Follow Us On Social Media
Facebook https://www.facebook.com/vectric
Instagram https://www.instagram.com/vectricltd/
Pinterest https://www.pinterest.co.uk/vectric/
YouTube https://www.youtube.com/channel/UCqkhkx ... y8ybykTlzQ
Vectric Newsletter November 2024
- Olly
- Vectric Staff
- Model of CNC Machine: ShopBot, CNC Shark
- Model of CNC Machine: xcarve
Re: Vectric Newsletter November 2024
I'm not having any luck opening the file. Do I need to convert something?
- Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
There are plenty of files available above. Which one in particular is THE one?
Trying to open the Santas Magic Key in Vectric. Just not loading correctly. Thanks
Both of these files (downloaded 2024-11-25) load fine with Aspire Trial v12.011:
I have the same file downloaded. I’m using vcarve pro. The magic key uploads but no tool paths are generated. I must be missing something. Just can’t figure what I’m missing . Thanks
- Model of CNC Machine: Genmitsu 3018-PROVer w/ 3040 extension
I'm having same issue. Says it is compatible with other versions however aspire is only ones in file. Where can we find the crv file for Vectric pro?
Answered over at this thread.
It's a V3M file which is just a 3D model. Once you've imported it you need to create a 3D roughing and finishing toolpath as you would normally with a 3D model.wkleatherwood wrote: ↑Fri Dec 06, 2024 1:23 amI have the same file downloaded. I’m using vcarve pro. The magic key uploads but no tool paths are generated. I must be missing something. Just can’t figure what I’m missing . Thanks
