Right sorry forgot to mention that.
I will look over your file and get back here soon.
Thank you!
Sharkcutup
Easy Box Maker 3.4 Small Text in config window
- sharkcutup
Re: Easy Box Maker 3.4 Small Text in config window
V-Carve Pro 12.013
V-Carve Pro 12.013
- sharkcutup
Okay I was right.
Do not use Parentheses or " in your Tool Names Example you had --- End Mill (1/4") Down Cut --- The Parentheses and the inches " notation around the 1/4 are not required.
I Changed from this End Mill (1/4") Down Cut (several places) to this End Mill 1/4 Down Cut in this file (Test Box-202411121428.Export) and the file Imports just fine now.
Here is the Corrected file below --- (Do Not forget to Change the .txt to .Export before attempting the Import)
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- sharkcutup
Since I have been involved with Gadgets so much I have had to learn the Naming Variables that Vectric has in the Tool Database for the Tool Naming Format. I have had to rename all my Tools in my Tool Database to that Naming Format to avoid any conflicts with the Gadgets Import Functions. And After learning the Vectric Naming Variables Format Strategy it made sense in that it not only shortened the length of the Naming Format but also got rid of unnecessary characters which could cause conflict in some coding instances. What is neat too is that with Version 12 the User is now able to create their own Variables (Ex: Cutting Height, MFG, Max RPM's, etc...).
Just Some Additional Thoughts!
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- Model of CNC Machine: Axiom Elite 4 X 4
Change My Tool Database descriptions and the import work fine. Never thought that was the problem.
Thanks to all for your help.
- sharkcutup
Great! Glad to hear your up and running. Anything else just ask here there are plenty of knowledgeable individuals here on this forum.
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- jimandi5000
Please test Ver3.7 and let me know.jimandi5000 wrote: ↑Wed Nov 13, 2024 11:00 pmI see a extra ")" in the code. I will post a fix ASAP.
FYI you may have issues with older EXPORT files.
Jim
Jim
