Easy Box Maker 3.3 Problem
- Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Re: Easy Box Maker 3.3 Problem
Yup. You keep saying that and it sounds hollower and hollower as an excuse for the program's behaviour every time.
Every feed rate, pass depth, and rpm setting for every tool in my tool database is set to values that are appropriate to my machine. If I create box using this program and choose one of those tools I am supremely confident that the settings are correct. The program should then create the toolpaths honouring those settings.
If it replaces my chosen RPM with 0 without my knowledge it is dishonouring my settings. If it doesn't pop up a message (and I haven't verified that it does) saying "Oh by the way, I set the RPMs to 0 to force you to edit the toolpaths and add in that RPM setting and maybe verify the other settings" then it is being dishonest in that it's hiding what it has done.
Out of the box the gadget fills in tools and settings. It shouldn't. If "the gadget has no way of knowing what type of Machine and how rigid that machine may be for the stresses applied if settings were initially provided" then why does it provide initial settings that may be wrong if a person looks at them and says "hmm, those are the size tools I'll be using so I'll just accept them"?
- sharkcutup
After further examination and review of this Gadget it has been determined ----
Okay so this is and has been the Problem Issue --- The Spindle Speed Code Designator/Variable had been left out of the Toolpathing for whatever reason. Without the Spindle Speed Code Designator/Variable within the code the gadget did the safest thing in putting a Zero (0) in the designated Spindle Speed input box --- it was given nothing so it entered nothing.
I have entered the Spindle Speed Code Designator/Variable for all the various tools in all areas of the Code Necessary for the next DOT Version of the Easy Box Maker Gadget. It will probably be Version 3.4. and will be out as soon.
Thank you all for your input.
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- jimandi5000
Hello All,
I have addressed an issue in Easy Box Joint Maker Ver3.4 Maker gadget.
Fixed:
1. Spindle speed issue in the gcode.
Supports: 11.0 and 12.01 version of 2D Cut Pro, VCarve Pro, and Aspire
Installation Instructions:
1. Open https://www.gadgets.jimandi.com/
2. Sort on the PostOrder column to see the most current post
3. Select the Download button for the EasyBoxJointMakerVer3.4.vgadget
4. In your Vectric product, click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it, and click Ok.
You should be presented a pop message up saying the gadget was installed and you should see the EasyBoxJointMakerVer3.4 in the Gadgets menu.
If you find an issue with any of the Easy gadgets, please let me know. I will do what I can to fix it within hours not days and weeks.
Without your feedback and suggestions the stone is sure hard to roll uphill. So keep them coming
Be sure to sign up on our gadget website to be notified by email when Easy Gadgets updates are posted.
Fixed:
Jim
Jim
- jimandi5000
Re: Easy Box Maker 3.5 Posted
Hello All,
I have addressed an issue in Easy Box Joint Maker Ver3.5 Maker gadget.
Fixed:
1. Added the Display Scale to the About menu.
3. Select the Download button for the EasyBoxJointMakerVer3.5.vgadget
You should be presented a pop message up saying the gadget was installed and you should see the EasyBoxJointMakerVer3.5 in the Gadgets menu.
Without your feedback and suggestions the stone is sure hard to roll uphill. So keep them coming.
Fixed:
Jim
Jim
- jimandi5000
I have addressed the error in Easy Box Joint Maker. look for Version 3.6 on the website.
Jim
Jim
- sharkcutup
Good Catch, Jim!jimandi5000 wrote: ↑Mon Nov 11, 2024 1:31 amI have addressed the error in Easy Box Joint Maker. look for Version 3.6 on the website.
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
