There is supposed to be a modeling tab on the bottom left next to or under Drawings, but it's not there and I can't find it anywhere.
The manual says the tab is normally found on the bottom left after Drawings, but no mention of where it is found abnormally.
Suggestions?
Ed
VCarve Pro Missing Modeling tab
- Model of CNC Machine: LongMill MK 2.5
Re: VCarve Pro Missing Modeling tab
What version are you running?
In V11.5 there was a modeling tab.
In V12 the modeling tools were moved to the Design tab
- sharkcutup
The Modeling Tab has been Renamed Components in Version 12.0 and Up See attached ---
And some of its features have been added to the Design Tab for convenience as noted in a previous post.
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
Thank you both for your thoughtful replies.
I am using VCarve Pro Version 12.
It took a lot of searching but I eventually found the modeling buttons.
Thanks again.
Thanks again.
