Game Board Maker_Ver1.0
- sharkcutup
Hello All,
Here is the First Release of the Game Board Maker. This Gadget creates Game Board Vector Layouts. Each Game Board Layout comes with Vectors layed out on Several Layers for ease of creating Toolpaths. There are Twenty-One(21) Game Board Layouts to choose from.
Item Changed/Added:
Nothing at this time for it is an Initial Release Version 1.0.
Rename to Game Board Maker_Ver1.0.vgadget
Current Version: 1.0
Supports: 12.0 versions of VCarve Pro, and Aspire -- Not sure about any of the other previous Vectric Versions for it has been created in Version 12.009
Installation Instructions:
1. Download the gadget Game Board Maker_Ver1.0.zip that is attached to this post.
2. Rename it from Game Board Maker_Ver1.0.zip to Game Board Maker_Ver1.0.vgadget
3. In Vectric Pro or Aspire click on Gadgets -> Install New Gadget and navigate to where you downloaded the file to, select it and click Ok.
It should give you a pop up saying the gadget was installed and you should see Game Board Maker Ver1.0 in the Gadgets Menu. After Installing Close Program then Restart Program for using Gadget.
Next up ---
Monitor Gadget Activity via this forum. Also if there are any other recommended Game Board Layouts you would like to see added to the Gadget bring them up I will see what can be done to add them.
If you find an issue with the gadget, please let me know. I will do what I can to fix it within hours not days and/or weeks.
Cheers,
Sharkcutup
Item Changed/Added:
Next up ---
Cheers,
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- RoutnAbout
Re: Game Board Maker_Ver1.0
Hey Shark,
Great gadget. Loaded without any errors.
I was able to load every game without any errors.
Didn't check to see if there were any open vectors, but that's a small easy fix if there are.
One small thing I seen with the Aggravation 4 and 6 Player,
The Stars were not centered on the circles.
I know it doesn't affect the game but my OCD kicking in.
Good Job!!
Good Job!!
- sharkcutup
Good catch thank You!
Enjoy the Gadget!
Sharkcutup
Enjoy the Gadget!
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- Model of CNC Machine: hd-510
Interesting. I found a couple of things I'd change if it was me.
On my laptop, 4K 16" screen, the initial box is 1/4 the size necessary to see the drop down and buttons. and the text in the buttons is very small.
If you can, I'd figure out the job size and center and scale the game board to fit. Right now it seems to be placed just off the lower left edge. Guess if I changed the reference to center instead of lower left it might make more sense. Maybe add a note to set the reference to center before clicking OK.
- sharkcutup
There is a note on gadget menu interface that says that the gadget is best used with x and y datum at the center. It also recommends a material board size of 22.0" (x) and 24.5" (y)
I will look at increasing size of menu interface so that things are not so small on the next revision.
Thank you for your input!
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
So there is, but on my machine it's about 3 point so basically unreadable.
- CrowsWW
- Model of CNC Machine: ShopSabre 4896
Very cool thanks
Troy Crow
Crow's Woodwork's
Wisdom is the reward for surviving our own stupidity!
-Wendel Volker
Crow's Woodwork's
-Wendel Volker
- Model of CNC Machine: CNC 6040, Vectric Aspire, UCCNC
I just tested it to create a Monopoly board. As I live in Sweden we use the metric system, I created a new file with the dimension 450 x 450 mm. The board came out at 17,5 x 17,5 mm
It was easy to select all vectors, press Shift key and drag it to the correct dimensions.
I re-tested it by creating a new file in imperial, 24 x 24 inches, the board was created at 17,5 x 17,5 inches,
Fun gadget that I certainly will use.
- sharkcutup
Re: Game Board Maker_Ver1.5
Hello All,
Here is an update of the Game Board Maker. This Gadget creates Game Board Vector Layouts. Each Game Board Layout comes with Vectors layed out on Several Layers for ease of creating Toolpaths. There are Twenty-One(21) Game Board Layouts to choose from.
Item Changed/Added:
1.) Made User interface a bit bigger and added a Pine Board Background.
2.) Fixed the Stars not centered on its PiP (Aggravation 4 and 6 player game boards).
Rename to Game Board Maker_Ver_1.5.vgadget
Current Version: 1.5
1. Download the gadget Game Board Maker_Ver_1.5.zip that is attached to this post.
2. Rename it from Game Board Maker_Ver_1.5.zip to Game Board Maker_Ver_1.5.vgadget
Next up ---
Continue Monitoring Gadget Activity via this forum. Also if there are any other recommended Game Board Layouts you would like to see added to the Gadget bring them up I will see what can be done to add them.
Cheers,
Sharkcutup
Item Changed/Added:
Next up ---
Cheers,
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- sharkcutup
I will look into the metric capabilities of the gadget. It is always great to see that there is also a work around (Select all vectors, hold Shift key down and go to any corner and drag to whatever size is required) in the meantime! It can also be sclaed usig the Size Tool (Set Selected Objects Size in Transform Objects).mickecarlsson wrote: ↑Sun Sep 15, 2024 8:05 pmI just tested it to create a Monopoly board. As I live in Sweden we use the metric system, I created a new file with the dimension 450 x 450 mm. The board came out at 17,5 x 17,5 mm![]()
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- Model of CNC Machine: Chinese6090
Hi
Thanks, looking forward to giving this gadget a go.
TJN
TJN
- Model of CNC Machine: my own design
I installed gadget in vcarve 11.554 and it worked when I created a scrabble board
Ed
Ed
- sharkcutup
Re: Game Board Maker_Ver1.6 (Metric Capability)
Hello All,
Here is an update of the Game Board Maker. This Gadget creates Game Board Vector Layouts. Each Game Board Layout comes with Vectors layed out on Several Layers for ease of creating Toolpaths. There are Twenty-One(21) Game Board Layouts to choose from. It now can be used in the Metric Units now too (No Longer Have to Scale Vectors to Correct Size)!
Item Changed/Added:
1.) Remove Error Message about flag on the Checkers Game Board
2.) Added Metric Capability of Gadget (No Longer Have to Scale Vectors to Correct Size)
Rename to Game Board Maker_Ver_1.6.vgadget
Current Version: 1.6
1. Download the gadget Game Board Maker_Ver_1.6.zip that is attached to this post.
2. Rename it from Game Board Maker_Ver_1.6.zip to Game Board Maker_Ver_1.6.vgadget
4.) Be Sure to Close Down Program (V-Carve or Aspire) for Install to fully take. Then Restart V-Carve or Aspire and select gadget to use/run.
Next up ---
Cheers,
Sharkcutup
Item Changed/Added:
Next up ---
Cheers,
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- sharkcutup
Hello All,
Sorry Found an Error on the Job Setup of this Gadget (Item 3 Noted Below).
Item Changed/Added:
3.) Fixed Error in XY Datum Messaging on Job Setup.
Rename to Game Board Maker_Ver_1.7.vgadget
Current Version: 1.7
1. Download the gadget Game Board Maker_Ver_1.7.zip that is attached to this post.
2. Rename it from Game Board Maker_Ver_1.7.zip to Game Board Maker_Ver_1.7.vgadget
It should give you a pop up saying the gadget was installed and you should see Game Board Maker Ver1.7 in the Gadgets Menu. After Installing Close Program then Restart Program for using Gadget.
Next up ---
Cheers,
Sharkcutup
Item Changed/Added:
Next up ---
Cheers,
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
In Game Board Maker Tools_Ver1.7.xlua there is a function PresentMessage that takes 3 arguments:
But, many instances pass 4 or even 5:
e.g. line 34:
e.g. line 75:
Line 607: the variable y is being treated as an integer but in line 603 it is defined as a string.
Line 626: there is a "function GetMaterialSettings()" the Joint in lines 635 to 641 doesn't seem to be used anywhere else.
Code: Select all
function PresentMessage(Header, Type, Line) -- Provides user information on an Error messages
e.g. line 34:
Code: Select all
PresentMessage("Alert", "Rotary Job was Selected", "This Gadget will not work on Job Type Rotary.", 165)
Code: Select all
PresentMessage("Alert", "XY Datum - Bottom Left Corner", "Bottom Left Corner XY Datum Position cannot be used with this gadget. Select the Center XY Datum.", "400", 165)
