I have a Stepcraft D3.840 with the 4th axis attachment using the A axis on UCCNS.
The attachment works and turns with manual commands through UCCNC.
I am using Vcarve Pro V12.006 using g-code arc mm.
I have a 1.5" x15" piece of stock on the Y axis that I want to use the rounding toolpath gadget on. The program creates the toolpath and the preview looks good. When I start the project the program it follows what should be the correct path and X and Y axis but it does not turn the 4th axis.
The A axis has been checked both on and off for rotary
I don't know G code but I cannot see anything in the code to tell the A axis to turn.
4th axis not turning
- Model of CNC Machine: Stepcraft D.840
Re: 4th axis not turning
You need to use a different post processor for rotary work.
This thread may help: UCCNC Post Processor
- TReischl
- Model of CNC Machine: Avid Type| Aspire V12 | Rhino| 3 Bambus
Here is another discussion that took place recently. It had me tearing out what little remaining hair I have.
viewtopic.php?f=38&t=43357
Thanks to your replies and several different wrap post processors I finally got it to work.
I used Mach 2/3-WrapY2A ATC
Thank you
Thank you
We want pictures!I finally got it to work.
We want pictures!
