error occured while writing toolpath to file ...
DizzyG
Model of CNC Machine: Onefinity Journeyman x50
Post by DizzyG »
A project I'm working on keeps giving me an "error occured while writing toolpath to file ..." message says to "Check that the file is not read only," (it's a new file as I've deleted all old .ngc files) "is not open in another application," (no other applications are using it), and "there is sufficient disk space available" ( there's over 930Gb available AND I've tried a different drive). Anyone have any ideas before I reload software?
Thanks, Eric
Why do it, if you're not going to do it right the 1st time?
adze_cnc
Re: error occured while writing toolpath to file ...
Post by adze_cnc »
I expect that it is the "\" in the file nam. Try "_" instead.
DizzyG
Post by DizzyG »
Nice catch, unfortunately that was not the fix, although it led me to the fix. I'm sure the "\" did not help but I had to remove the inch ( " ) punctuation from the file name also.
Thank you, your suggestion led me down the path to get it fixed.
Eric
