laser power and speed test file
rmcdonal
Post by rmcdonal »
Has anyone made or found a laser power and speed test file that will work in Aspire? A gcode extension file would be great to work with my Atomstack x20 laser.
LittleGreyMan
Re: laser power and speed test file
Post by LittleGreyMan »
Have a look at these files: https://www.thingiverse.com/thing:728579/files
What do you mean by a "test file that will work in Aspire" and "A gcode extension file would be great"? If you get a gcode file, Aspire won't be necessary and if you get an Aspire readable file, you'll be able to generate g-code.
wilkigr
Model of CNC Machine: Sienci Long Mill
Post by wilkigr »
If you strike out on one that will open in Aspire, look at the LAHobbyGuy site. He has an excellent set that will run in LB.
