Gadget with two or more paths
This forum has been created for users to submit suggestions for Gadgets
Fernando
Model of CNC Machine: Router CNC 3,4 and 5 axis
Post by Fernando »
I need to create a Gadget similar to the one below, but that performs more than one operation on the same Gadget.
For example:
Cut path with cut layer
Roughing toolpath with Roughing layer
V-carve path for Vcarve layer
And so on
I tested it in a few ways but it always runs only one route.
Can you help me?
Another thing is that I am not able to generate the G-code automatically through the Gadget as shown in the SDK examples.
Thanks a lot if you can help me with these questions.
-- VECTRIC LUA SCRIPT
-- Copyright 2013 Vectric Ltd.
-- Gadgets are an entirely optional add-in to Vectric's core software products.
-- They are provided 'as-is', without any express or implied warranty, and you make use of them entirely at your own risk.
-- In no event will the author(s) or Vectric Ltd. be held liable for any damages arising from their use.
-- Permission is granted to anyone to use this software for any purpose,
-- including commercial applications, and to alter it and redistribute it freely,
-- subject to the following restrictions:
-- 1. The origin of this software must not be misrepresented; you must not claim that you wrote the original software. If you use this software in a product, an acknowledgment in the product documentation would be appreciated but is not required.
-- 2. Altered source versions must be plainly marked as such, and must not be misrepresented as being the original software.
-- 3. This notice may not be removed or altered from any source distribution.
require "strict"
--[[  ---------------- SelectVectorsOnLayer ----------------
|   Add all the vectors on the layer to the selection
|     layer,            -- layer we are selecting vectors on
|     selection         -- selection object
|     select_closed     -- if true  select closed objects
|     select_open       -- if true  select open objects
|     select_groups     -- if true select grouped vectors (irrespective of open / closed state of member objects)
|  Return Values:
|     true if selected one or more vectors
function SelectVectorsOnLayer(layer, selection, select_closed, select_open, select_groups)
   local objects_selected = false
   local warning_displayed = false
   local pos = layer:GetHeadPosition()
      while pos ~= nil do
    local object
         object, pos = layer:GetNext(pos)
         local contour = object:GetContour()
         if contour == nil then
            if (object.ClassName == "vcCadObjectGroup") and select_groups then
               selection:Add(object, true, true)
               objects_selected = true
            else
               if not warning_displayed then
                  local message = "Object(s) without contour information found on layer - ignoring"
                  if not select_groups then
                     message = message ..
                               "\r\n\r\n" ..
                               "If layer contains grouped vectors these must be ungrouped for this script"
                  end
                  DisplayMessageBox(message)
                  warning_displayed = true
               end
            end
         else  -- contour was NOT nil, test if Open or Closed
            if contour.IsOpen and select_open then
            else if select_closed then
            end
         end
         end
      end
   -- to avoid excessive redrawing etc  we added vectors to the selection in 'batch' mode
   -- tell selection we have now finished updating
   if objects_selected then
      selection:GroupSelectionFinished()
   end
   return objects_selected
end
--[[  ---------------- CreateLayerProfileToolpath ----------------
|   Create an outside Profile toolpath within the program for vectors on the passed layer
|  Parameters:
|     job               -- Job we are working with
|     layer_name        -- Name of layer we will profile vectors for
|     name              -- Name for toolpath
|     start_depth       -- Start depth for toolpath below surface of material
|     cut_depth         -- cut depth for profile toolpath
|     tool_dia          -- diameter of end mill to use
|     tool_stepdown     -- stepdown for tool
|     tool_in_mm        -- true if tool size and stepdown are in mm
|  Return Values:
|     true if toolpath created OK else false
function CreateLayerProfileToolpath( job, layer_name, name , start_depth, cut_depth, tool_dia, tool_stepdown, tool_in_mm)
   -- clear current selection
   local selection = job.Selection
   selection:Clear()
   -- get layer
   local layer = job.LayerManager:FindLayerWithName(layer_name)
   if layer == nil then
      DisplayMessageBox("No layer found with name = " .. "\"" ..  layer_name .. "\"")
      return false
   end
   -- select all closed vectors on the layer
   if not SelectVectorsOnLayer(layer, selection, true, false, true) then
      DisplayMessageBox("No closed vectors found on layer " .. "\"" .. layer_name .. "\"")
      return false
   end
   -- Create tool we will use to machine vectors
   local tool = Tool(
                    "Lua End Mill",
                    Tool.END_MILL       -- BALL_NOSE, END_MILL, VBIT
   tool.InMM = tool_in_mm
   tool.ToolDia = tool_dia
   tool.Stepdown = tool_stepdown
   tool.Stepover = tool_dia * 0.25
   tool.RateUnits = Tool.MM_SEC  -- MM_SEC, MM_MIN, METRES_MIN, INCHES_SEC, INCHES_MIN, FEET_MIN
   tool.FeedRate = 30
   tool.PlungeRate = 10
   tool.SpindleSpeed = 20000
   tool.ToolNumber = 1
   tool.VBitAngle = 90.0                -- used for vbit only
   tool.ClearStepover = tool_dia * 0.5  -- used for vbit only
   -- we will set home position and safe z relative to material block size
   local mtl_block = MaterialBlock()
   local mtl_box = mtl_block.MaterialBox
   local mtl_box_blc = mtl_box.BLC
   -- Create object used to set home position and safez gap above material surface
   local pos_data = ToolpathPosData()
   pos_data:SetHomePosition(mtl_box_blc.x, mtl_box_blc.y, mtl_box.TRC.z + (mtl_block.Thickness * 0.2) )
   pos_data.SafeZGap = mtl_block.Thickness * 0.1
   -- Create  object used to pass profile options
   local profile_data = ProfileParameterData()
      -- start depth for toolpath
      profile_data.StartDepth = start_depth
      -- cut depth for toolpath this is depth below start depth
      profile_data.CutDepth = cut_depth
      -- direction of cut - ProfileParameterData.CLIMB_DIRECTION or ProfileParameterData.CONVENTIONAL_DIRECTION
      profile_data.CutDirection = ProfileParameterData.CLIMB_DIRECTION
      -- side we machine on - ProfileParameterData.PROFILE_OUTSIDE,  ProfileParameterData.PROFILE_INSIDE or ProfileParameterData.PROFILE_ON
      profile_data.ProfileSide = ProfileParameterData.PROFILE_OUTSIDE
      -- Allowance to leave on when machining
      profile_data.Allowance = 0.0
      -- true to preserve start point positions, false to reorder start points to minimise toolpath length
      profile_data.KeepStartPoints = false
      -- true if want to create 'square' external corners on toolpath
      profile_data.CreateSquareCorners = false
      -- true to perform corner sharpening on internal corners (only with v-bits)
      profile_data.CornerSharpen = false
      -- true to use tabs (position of tabs must already have been defined on vectors)
      profile_data.UseTabs = false
      -- length for tabs if being used
      profile_data.TabLength = 5.0
      -- Thickness for tabs if being used
      profile_data.TabThickness = 1.0
      -- if true then create 3d tabs else 2d tabs
      profile_data.Use3dTabs  = true
      -- if true in Aspire, project toolpath onto composite model
      profile_data.ProjectToolpath = false
   -- Create object used to control ramping
   local ramping_data = RampingData()
      -- if true we do ramping into toolpath
      ramping_data.DoRamping = false
      -- type of ramping to perform RampingData.RAMP_LINEAR , RampingData.RAMP_ZIG_ZAG or RampingData.RAMP_SPIRAL
      ramping_data.RampType = RampingData.RAMP_ZIG_ZAG
      -- how ramp is contrained - either by angle or distance RampingData.CONSTRAIN_DISTANCE or RampingData.CONSTRAIN_ANGLE
      ramping_data.RampConstraint = RampingData.CONSTRAIN_ANGLE
      -- if we are constraining ramp by distance, distance to ramp over
      ramping_data.RampDistance = 100.0
      -- if we are contraining ramp by angle , angle to ramp in at (in degrees)
      ramping_data.RampAngle = 25.0
      -- if we are contraining ramp by angle, max distance to travel before 'zig zaging' if zig zaging
      ramping_data.RampMaxAngleDist = 15
      -- if true we restrict our ramping to lead in section of toolpath
      ramping_data.RampOnLeadIn = false
   -- Create object used to control lead in/out
   local lead_in_out_data = LeadInOutData()
      -- if true we create lead ins on profiles (not for profile on)
      lead_in_out_data.DoLeadIn = false
      -- if true we create lead outs on profiles (not for profile on)
      lead_in_out_data.DoLeadOut = false
      -- type of leads to create LeadInOutData.LINEAR_LEAD or LeadInOutData.CIRCULAR_LEAD
      lead_in_out_data.LeadType = LeadInOutData.CIRCULAR_LEAD
      -- length of lead to create
      lead_in_out_data.LeadLength = 10.0
      -- Angle for linear leads
      lead_in_out_data.LinearLeadAngle = 45
      -- Radius for circular arc leads
      lead_in_out_data.CirularLeadRadius = 5.0
      -- distance to 'overcut' (travel past start point) when profiling
      lead_in_out_data.OvercutDistance = 0.0
   -- Create object which can used to automatically select geometry on layers etc
   local geometry_selector = GeometrySelector()
   -- if this is true we create 2d toolpaths previews in 2d view, if false we dont
   local create_2d_previews = true
   -- if this is true we will display errors and warning to the user
   local display_warnings = true
   -- Create our toolpath
   local toolpath_manager = ToolpathManager()
   local toolpath_id = toolpath_manager:CreateProfilingToolpath(
                                              name,
                                              tool,
                                              profile_data,
                                              ramping_data,
                                              lead_in_out_data,
                                              pos_data,
 geometry_selector,
                                              create_2d_previews,
                                              display_warnings
   if toolpath_id  == nil  then
      DisplayMessageBox("Error creating toolpath")
      return false
   end
   return true
end
--[[  ______________________ main --------------------------------------------------
|  Entry point for script
function main()
    -- Check we have a job loaded
    local job = VectricJob()
    if not job.Exists then
       DisplayMessageBox("No job loaded")
       return false;
    end
    local layer_name = "Layer 1"
    local start_depth = 0.0
    local cut_depth = mtl_block.Thickness
    local tool_dia = 3.0
    local tool_stepdown = 1.0
    local tool_in_mm = true
    local success = CreateLayerProfileToolpath(
                                         job,
                                              layer_name,
                                              "Lua Profile Toolpath",
                                              start_depth,
                                              cut_depth,
                                              tool_dia,
                                              tool_stepdown,
                                              tool_in_mm
    return success;
end
jimandi5000
Re: Gadget with two or more paths
Post by jimandi5000 »
Fernando wrote:
Wed Dec 21, 2022 12:07 pm
For example:
And so on
Can you help me?
require "strict"
|  Return Values:
      while pos ~= nil do
    local object
            else
                               "\r\n\r\n" ..
                  end
               end
            end
            end
         end
         end
      end
   end
end
|  Parameters:
|  Return Values:
   selection:Clear()
   -- get layer
      return false
   end
      return false
   end
   local tool = Tool(
                    "Lua End Mill",
   tool.FeedRate = 30
   tool.ToolNumber = 1
                                              name,
                                              tool,
                                              profile_data,
                                              ramping_data,
                                              lead_in_out_data,
                                              pos_data,
 geometry_selector,
                                              create_2d_previews,
                                              display_warnings
      return false
   end
   return true
end
function main()
       return false;
    end
                                         job,
                                              layer_name,
                                              start_depth,
                                              cut_depth,
                                              tool_dia,
                                              tool_stepdown,
                                              tool_in_mm
    return success;
end
Hi Fernando,
I would write code to loop for each layer you want to process.
let me know if you need help building the loop code.
Jim
adze_cnc
Post by adze_cnc »
You seem to be on the right course. It's just a case of adding the require functions and calls for what you want:
Code: Select all
function CreateLayerProfileToolpath(...)
function CreateLayerVCarveToolpath(...)
function CreateLayerRoughingToolpath(...)
etc.
function main()
success = CreateLayerProfileToolpath(...)
success = CreateLayerVCarveToolpath(...)
success = CreateLayerRoughingToolpath(...)
etc.
Remember that the :CreateRoughingToolpath and :CreateFinishingToolpath methods are for Aspire only.
Please note that every instance of:
Code: Select all
tool.VBitAngle = ...
in the SDK document is wrong (and has been since at least 2013). If you use that you will always get a 90 degree bit no matter what value you specify. The actual way to reference it is:
Code: Select all
tool.VBit_Angle = ...
Note that when including code snippets in a forum post you can use the code tags as in the image below (the blue circle icon puts them in for you).
Steven
adze_cnc
Post by adze_cnc »
Would that be the "ToolSaver" discussed in the SDK? If so, after creating the toolpaths programmatically you might need to run something to refresh the list. Otherwise the ToolSaver might not see what you've just created. Much like after drawing some objects you need to refresh the view.
I haven't got a clue what that refresh command might be (if it is necessary).
You may want to look at this V9 gadget - https://gadgets.vectric.com/V9/apply_template - for further examples of saving code directly.
I haven't looked to see if the calls are all still valid in the latest versions but the code I wrote back then certainly wrote out multiple toolpaths without issues.
Fernando
Post by Fernando »
I'm on my way
I was able to create for 2 cutting paths
but for the error filling path, see:
require "strict"
| Return Values:
while pos ~= nil do
local object
else
"\r\n\r\n" ..
end
end
end
end
end
end
end
end
end
| Parameters:
| Return Values:
----- Percurso de Corte Canal ----
function Percurso_de_Corte_01( job, layer_name, name , start_depth, cut_depth, tool_dia, tool_stepdown, tool_in_mm)
selection:Clear()
-- get layer
return false
end
return false
end
local tool = Tool(
"Esferica 10mm",
Tool.BALL_NOSE -- BALL_NOSE, END_MILL, VBIT
tool.RateUnits = Tool.MM_MIN -- MM_SEC, MM_MIN, METRES_MIN, INCHES_SEC, INCHES_MIN, FEET_MIN
tool.FeedRate = 2500
tool.PlungeRate = 2500
tool.SpindleSpeed = 18000
tool.ToolNumber = 1
profile_data.ProfileSide = ProfileParameterData.PROFILE_ON
ramping_data.DoRamping = true
ramping_data.RampType = RampingData.RAMP_LINEAR
name,
tool,
profile_data,
ramping_data,
lead_in_out_data,
pos_data,
geometry_selector,
create_2d_previews,
display_warnings
return false
end
return true
end
---- Corte 2 ----
function Percurso_de_Corte_02( job, layer_name, name , start_depth, cut_depth, tool_dia, tool_stepdown, tool_in_mm)
selection:Clear()
-- get layer
return false
end
return false
end
local tool = Tool(
"Topo Reto 6mm",
tool.SpindleSpeed = 15000
tool.ToolNumber = 1
ramping_data.RampType = RampingData.RAMP_SPIRAL
name,
tool,
profile_data,
ramping_data,
lead_in_out_data,
pos_data,
geometry_selector,
create_2d_previews,
display_warnings
return false
end
return true
end
---- Preenchimento
function Percurso_de_Preenchimento( job, layer_name, name , start_depth, cut_depth, tool_dia, tool_stepdown, tool_in_mm)
selection:Clear()
-- get layer
return false
end
return false
end
local tool = Tool(
"Topo Reto 22mm",
tool.ToolNumber = 1
--- Create object used to pass pocketing options
local pocket_data = PocketParameterData()
pocket_data.StartDepth = start_depth
--> if true use raster clearance strategy , else use offset area clearance
pocket_data.DoRasterClearance = true
--> angle for raster if using raster clearance
pocket_data.RasterAngle = 0
--> type of profile pass to perform PocketParameterData.PROFILE_NONE , PocketParameterData.PROFILE_FIRST orPocketParameterData.PROFILE_LAST
pocket_data.ProfilePassType = PocketParameterData.PROFILE_LAST
--> if true we ramp into pockets (always zig-zag)
pocket_data.DoRamping = false
--> if ramping, distance to ramp over
pocket_data.RampDistance = 10.0
--> if true in Aspire, project toolpath onto composite model
pocket_data.ProjectToolpath = false
-- if we are doing two tool pocketing define tool to use for area clearance
local area_clear_tool = false
-- we just create a tool twice as large for testing here
area_clear_tool = Tool(
"Lua Clearance End Mill",
area_clear_tool.InMM = tool_in_mm
area_clear_tool.ToolDia = tool_dia * 2
area_clear_tool.Stepdown = tool_stepdown * 2
area_clear_tool.Stepover = tool_dia * 2 *(tool_stepover_percent / 100)
area_clear_tool.RateUnits = Tool.MM_SEC -- MM_SEC, MM_MIN, METRES_MIN, INCHES_SEC, INCHES_MIN, FEET_MIN
area_clear_tool.FeedRate = 30
area_clear_tool.PlungeRate = 10
area_clear_tool.SpindleSpeed = 20000
area_clear_tool.ToolNumber = 1
area_clear_tool.VBitAngle = 90.0 -- used for vbit only
area_clear_tool.ClearStepover = tool_dia * 2 * (tool_stepover_percent / 100) -- used for vbit only
local toolpath_id = toolpath_manager:CreatePocketingToolpath(
name,
tool,
area_clear_tool,
pocket_data,
pos_data,
geometry_selector,
create_2d_previews,
display_warnings
return false
end
return true
end
function main()
return false;
end
--Percurso Canal Gordura
local layer_name1 = "Canal"
local cut_depth = 8
local tool_dia = 10.0
local tool_stepdown = 2.0
local success = Percurso_de_Corte_01(
job,
layer_name1,
"Canal",
start_depth,
cut_depth,
tool_dia,
tool_stepdown,
tool_in_mm
--Percurso Corte Final
local layer_name2 = "Corte Final"
local cut_depth = mtl_block.Thickness +1
local tool_dia = 6.0
local success = Percurso_de_Corte_02(
job,
layer_name2,
"Corte Final",
start_depth,
cut_depth,
tool_dia,
tool_stepdown,
tool_in_mm
---- Desbaste
local layer_name3 = "Rebaixo"
local cut_depth = mtl_block.Thickness * 0.25
local tool_dia = 12.0
local tool_stepdown = 2.5
local tool_stepover_percent = 50.0
local success = Percurso_de_Preenchimento( job, layer_name2,
"Rebaixo",
start_depth,
cut_depth,
tool_dia,
tool_stepdown,
tool_stepover_percent,
tool_in_mm
return success;
end
Fernando
Post by Fernando »
adze_cnc wrote:
Wed Dec 21, 2022 6:57 pm
It's not that
