I'm simply want to loop through all entities on a layer and put them in a group.
I went through the SDK last night and couldn't find an example.
I must be over looking it.
Can someone post some lua to just go through all entities on a layer and put them in a group please?
Looping though entities on a layer and putting in a group
Re: Looping though entities on a layer and putting in a group
On my phone at the moment so can't check but from memory the Chamfer Gadget has code to do that - https://gadgets.vectric.com/V11/chamfer
- jimandi5000
Hi Reggieaj,reggieaj wrote: ↑Mon Jun 20, 2022 9:54 pmI'm simply want to loop through all entities on a layer and put them in a group.
Here is a function I use to group objects to a layer
Code: Select all
function AddGroupToJob(job, group, layer_name)
--[[ --------------- AddGroupToJob --------------------
| Add passed group to the job - returns object created
| Parameters:
| job -- job we are working with
| group -- group of contours to add to document
| layer_name -- name of layer group will be created on|
| Return Values:
| object created to represent group in document
-- create a CadObject to represent the group
local cad_object = CreateCadGroup(group);
-- create a layer with passed name if it doesnt already exist
local layer = job.LayerManager:GetLayerWithName(layer_name)
-- and add our object to it
layer:AddObject(cad_object, true)
return cad_object
end
Code: Select all
local Group = ContourGroup(true)
local job = VectricJob()
local line = Contour(0.0)
line:AppendPoint(pB1)
line:LineTo(pE2)
line:LineTo(pE3)
line:LineTo(pB4)
line:LineTo(pB5)
group:AddTail(line)
line = Contour(0.0)
line:AppendPoint(pB3)
line:LineTo(pC3)
line:LineTo(pK8)
line:LineTo(pB8)
line:LineTo(pE3)
group:AddTail(line)
AddGroupToJob(job, Group, "Jim")
Jim
Jim
My goal is to not have to select geometry or create geometry in or to group.
I see from the SDK how to add to group if entities are selected or created but not if they already exist.
What I want to do is start looping through all of the existing geometry on a layer (without having to select anything)
and add all of the geometry on the layer to a group.
I could not find a way to loop through existing geometry on a layer!!!
Granted I only started looking last night. But I would have thought this would be easy to find.
Pseudo Code:
Open Vcarve
Load File
Start Gadget
For each layer in file
Create a new group
For each entity on a layer 'No selection. Just traverse the entities without selecting 1st
Add the entity to a group
Loop End
Loop End
Create Tool Path
Simple enough. But I couldn't find way to do it!!
I think it's just my inexperience with Lua. Surely this has been done before.
Please help. Trying to impress boss in the morning with some automation.
Pseudo Code:
Open Vcarve
Load File
Start Gadget
Create a new group
Loop End
Loop End
Create Tool Path
One of the sample files in the SDK (under "Samples - General”) is a layer example. In that example it counts the number of objects on the layer. It’s not a large step from counting objects to adding them to a layer as you count them.
adze_cnc,
I'll take a closer look at that. It was the most promising from last night.
I wasn't sure it was exposing the object ID. If it is then I should be good.
Thanks.
Thanks.
- jimandi5000
You can also select geometry on a layer by using the select vectors on layer function (listed below) you can find the code in the SDK
Code: Select all
function SelectVectorsOnLayer(layer, selection, select_closed, select_open, select_groups)
-- Please Note: SelectVectorsOnLayer is provided by Vectric and can be found in the SDK and Sample Gadget files.
--[[ ---------------- SelectVectorsOnLayer ----------------
-- | SelectVectorsOnLayer("Stringer Profile", selection, true, falus, falus)
-- | Add all the vectors on the layer to the selection
-- | layer, -- layer we are selecting vectors on
-- | selection -- selection object
-- | select_closed -- if true select closed objects
-- | select_open -- if true select open objects
-- | select_groups -- if true select grouped vectors (irrespective of open / closed state of member objects)
-- | Return Values:
-- | true if selected one or more vectors|
local objects_selected = false
local warning_displayed = false
local pos = layer:GetHeadPosition()
while pos ~= nil do
local object
object, pos = layer:GetNext(pos)
local contour = object:GetContour()
if contour == nil then
if (object.ClassName == "vcCadObjectGroup") and select_groups then
selection:Add(object, true, true)
objects_selected = true
else
if not warning_displayed then
local message = "Object(s) without contour information found on layer - ignoring"
if not select_groups then
message = message .. "\r\n\r\n" ..
"If layer contains grouped vectors these must be ungrouped for this script"
end -- if end
DisplayMessageBox(message)
warning_displayed = true
end -- if end
end -- if end
else -- contour was NOT nil, test if Open or Closed
if contour.IsOpen and select_open then
elseif select_closed then
end -- if end
end -- if end
end -- while end
-- to avoid excessive redrawing etc we added vectors to the selection in 'batch' mode
-- tell selection we have now finished updating
if objects_selected then
selection:GroupSelectionFinished()
end -- if end
return objects_selected
end -- function end
Jim
Jim
Ah. function SelectVectorsOnLayer(layer, selection, select_closed, select_open, select_groups) looks like exactly what I need.
I'll give a go.
Thank you very much!!!!!!!!!!!!
I'll give a go.
- jimandi5000
