Easy MDF Cabinet Door Maker
jimandi5000
Re: Easy MDF Cabinet Door Maker
Post by jimandi5000 »
Hello All,
I have addressed an issue in Easy MDF Cabinet Door Maker gadget.
Fixed:
1. No Scribe Lines in batch mode.
2. Help button pointing to wrong help file
Added:
1. Color selection for layers
2. Updated Menu Layout
3. Updated Help items
Current Version: 13.5
Supports: 11.0+ version of 2D Cut Pro, VCarve Pro, and Aspire
Installation Instructions:
1. Open https://www.gadgets.jimandi.com/
2. Sort on the PostOrder column to see the most current post
3. Select the Download button for the EasyMDFCabinetDoorMakerVer13.5.vgadget
4. In your Vectric product, click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it, and click Ok.
You should be presented a pop message up saying the gadget was installed and you should see the EasyMDFCabinetDoorMakerVer13.5 in the Gadgets menu.
If you find an issue with any of the Easy gadgets, please let me know. I will do what I can to fix it within hours not days and weeks.
Without your feedback and suggestions the stone is sure hard to roll uphill. So keep them coming
Be sure to sign up on our gadget website to be notified by email when Easy Gadgets updates are posted.
Gadget Menu
Gadget Menu
Door Styles
Door Styles
Multi Panel Door
Multi Panel Door
Jim
Jimcad
Model of CNC Machine: Alpha CNC 6090 with 4th Axis
Post by Jimcad »
Very good Jim.
Jim
cusoak
Post by cusoak »
HOWDO I FIND THE GADGET WEB SITE ALSO i WANT TO LEARN ABOUT THE BITS IT TAKES TO MAKE A RAISED PANNEL DOOR ..IF I POST A SIZE HERE THAT I WANT TO MAKE COULD SOME ONE HERE SET UP THE TOOL PATHS WITH THE CO CORRECT BITS WITH SPEEDS AND FEEDSPEEDS IN A VECTRIC FILE iHAVE CUT THE SHAKER STYLE MDF DOOR tHANKS JEFF PETERS i HAVE A SHAPEOKO5 4X4 PRO CNC i CAN CUT 4X8 SHEETS OF MDF AND PLYWOOD. ALSO CAN THE DOOR GADGET ALSO BE USED WITH GLUED UP 3/4" THICK WOOD WITH THE PROPER BITS tHANKS JEFF PETERS
Post by Rcnewcomb »
HOW DO I FIND THE GADGET WEB SITE
Link: https://www.gadgets.jimandi.com/
RDKDust
Model of CNC Machine: Yeti SmartBench
Post by RDKDust »
Jim,
Were you at the Austin users group this year, Swear I saw you but I could not get next to you. Maybe next year.
I was getting ready to write a tool to do this until I found yours. Now no need to. Gadget is wonderful.
I have a suggestion. I was using a tool that I found at tools today.
Here is the video link if you look at about 56 seconds on the time line you see that they are using a 3D effect to actually square the corners with the VBit. In using this it is actually square and gets rid of the last of the rounding. Is this something that can be added to your gadget specifically for shaker style doors.
Bob
sharkcutup
Post by sharkcutup »
See this Link --- viewtopic.php?p=324101#p324101
I will take a look at the video in your post and see if there may be something I can do to add what you are asking for.
Sharkcutup
V-Carve Pro 12.013
sharkcutup
After looking at the video in your post I see what you are looking for. I have run MDF Cabinet Door Maker and found the this is already in the gadget. In the Tooling selection select a V-Bit for both the Inside Edge, Outside Edge and Panel Forming. Also in Defaults Set the Raised Panel Bit and the Scribe Bit as desired.
If you have any other questions I will be happy to assist you. I may not be of Jim's Caliber in LUA Coding Knowledge but I am not afraid to give whatever may be needed a go.
And Yes Jim was at the UGM in Austin.
Sharkcutup
V-Carve Pro 12.013
sharkcutup
Here is an MDF Shaker Door Style created with the Version 13.5 MDF Door Maker Gadget. Created with Settings I had Noted in my previous post.
Will this Satisfy What you are wanting?
Sharkcutup
V-Carve Pro 12.013
sharkcutup
Hello Everyone,
I have addressed an issue in Easy MDF Cabinet Door Maker gadget where the VBit angle was not being displayed correctly in the Toolpaths using VBits.
Fixed:
1. VBit Angle Display Correctly
2. Other minor code adjustments
Added:
1. Nothing at the Present Time.
EasyMDFDoorMaker_Ver13.6.vgadget
(2.5 MiB) Downloaded 34 times
Current Version: 13.6
1. Download Gadget to your Computer as is. DO NOT CHANGE ANYTHING!
2. Open Aspire or V-Carve.
3. From Gadgets Menu Select Install Gadget.
4. Find downloaded gadget on your computer that you had just downloaded and Select it then Click OK.
5. After a few seconds you will get a message that the gadget had successfully installed.
6. Be sure to close program (Aspire or V-Carve) to complete the install before attempting to use it.
Without your feedback and suggestions the stone is sure hard to roll uphill. So keep them coming.
Sharkcutup
V-Carve Pro 12.013
Jimcad
Post by Jimcad »
Thanks Shark.
Jim
