My First Guitar Body
sharkcutup
Post by sharkcutup »
1963 Stratocaster carved out of White Oak
Thought I would give it a go!!! Another interesting/challenging project!
SHARKCUTUP
Hogan's CNC Crafts
One on One V-Carve Help is Available!!!
PM me for details!
V-Carve Pro 11.006
Re: My First Guitar Body
Post by Rcnewcomb »
It looks great. What size ballnose bit did you use for the finish pass?
(Long, long ago I had a '56 Strat which I sold for $250 in my foolish youth.)
10 fingers in, 10 fingers out
another good day in the shop
sharkcutup
Thank you!!!🙂
This build was drawn from a paper drawing.
Most complicated Toolpaths used were Moulding toolpaths cleared with 1/4" flat end mill and finished with a 1/4" ballnose.
Sharkcutup
Hogan's CNC Crafts
PM me for details!
V-Carve Pro 11.006
TomWS
Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Post by TomWS »
Very nice two sided carving! The pockets look very deep. What was the cutting length on the bit?
scotttarnor
Model of CNC Machine: Piranha XL , Shark HD520
Post by scotttarnor »
Dam Dude you do everything from rifle stocks to guitar’s ! I want to come hang out in garage for a day!
Scott T
@scottscnc
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP10.5**
Post by scottp55 »
Sweet and clean cut Shark!! :)
Well Done!
"When in doubt...Zero it out!"
No idea who, but first saying I learned the Hard Way
sharkcutup
Thank you everyone!
I Enjoy Challenges!!! Two-Side Projects are even more Interesting and Challenging too!
2 1/4" stock material - White Oak planed to 2" for project. Required project completed thickness - 1 3/4"
Pockets - .563" and 1.5" deep and one through pocket using a 1/4" Flat End Mill 3" Overall length - 1" cutting length
It was definitely a challenge and that first guitar body is not perfect by any means (note the contour face side).
This project for me required two z-zero locations because I am very partial to using Virtual Z-Zero setups. In that instance I had used the wrong Z-Zero at the startup of that particular moulding toolpath which regrettably started .25" deep which caused a surmountable amout of sanding to blend/smooth surface to machined contour. Other than that I believe the First go was proven a success!
Sharkcutup
Hogan's CNC Crafts
PM me for details!
V-Carve Pro 11.006
sharkcutup
I think I will have a go at the Fender Telecaster Thinline Guitar Body in White Oak. It will be a lot lighter due to the Thinline's hollow design feature. It will be even more challenging because not only is it two-sided, it is made up of two mating parts - the hollowed body and a matching cover.
Hmmm where did I put that drawing?
Sharkcutup
Hogan's CNC Crafts
PM me for details!
V-Carve Pro 11.006
rink
Model of CNC Machine: CNC Piranha / VCarve Desktop
Post by rink »
sharkcutup wrote:
Sat May 22, 2021 3:18 pm
Good evening.
What are virtual z-zero setups?
Thx, rink.
sharkcutup
sharkcutup wrote: ↑Sat May 22, 2021 9:18 am
Good evening.
Thx, rink.
I was a little hesitant mentioning Virtual Z-Zero Setups because of this.
Virtual Zero is a program that had come with my Shark CNC Control Software which I have grown accustomed to using most often.
Reference this link - https://www.nextwavecnc.com/shop/hex:73 ... 205a65726f
for more information on what it is and its capabilities.
Sharkcutup
Hogan's CNC Crafts
PM me for details!
V-Carve Pro 11.006
rink
Post by rink »
Thank you.
