node editing
yossef
Model of CNC Machine: workbee
node editing
Post by yossef »
Hello everyone
Question - What is the shortcut to vector alignment in node editing? Yosef
Re: node editing
The standard vector alignment tools work when you're in node edit mode. There are no shortcuts for them in either mode.
SteveNelson46
Model of CNC Machine: Camaster Stinger/WinCNC
Re: node editing
Post by SteveNelson46 »
Not sure I completely understand your question but you can align nodes using the keyboard short cut keys. Select each node by holding down the shift key and then press "X" for vertical alignment or "Y" for horizontal.
