cutting 4 flat surfaces
rej
Model of CNC Machine: 2014 roc-tech 4x8 with servos
Post by rej »
my question..... say i wanted to flute 4 flat surfaces, and i don't want to turn the piece of stock manually. can i put it in the rotary and have the rotary turn the piece after the toolpaths are run for each side?
http://www.3dsigncamp.com
http://www.roctechusacnc.com
Re: cutting 4 flat surfaces
Post by Rcnewcomb »
You would either need to rotate the piece between toolpaths, or to manually edit the G code to include the rotate commands.
10 fingers in, 10 fingers out
another good day in the shop
rej
Post by rej »
i have no desire to manually rotate the piece. so i will need to learn to edit the gcode. i'll bet there are many people like myself who are intimidated by that. but i think i have a guy who can teach me. thanks for the answer.
SteveNelson46
Model of CNC Machine: Camaster Stinger/WinCNC
Post by SteveNelson46 »
Something like this? With a project of 4" diameter and 12" long I created 2 boxes. One 3.5" and the other 2". Then I used the vector un-wrapper on each and used a 2-rail sweep with the profiles created by the un-wrapper at each end. Might need to play around with (or add) profiles to achieve different results.
Post by TReischl »
One thing to think about when using a rotary as an indexer. . . .
When the tool moves off the C/L it can move the stepper when it plunges. Good indexers and rotaries that can be used in that manner have a "clamp" function that locks the rotary spindle in place.
Just a note, the same problem exists with a servo motor.
4DThinker
Post by 4DThinker »
I if your control software has a place to enter G-code commands, then 3 simple typed in commands will do the rotation for you:
G0A90
G0A180
G0A270
I use LinuxCNC and have done this many times, but usually just to cut mortises on table legs after having done the rest of the leg as a typical rotary job.
Your fluting commands shouldn't put much moment forces on a rotary stepper given their normal ramping action.
