Size of a box
cusoak
Size of a box
Post by cusoak »
In the gadget box creator using the Square Tabs.
If I want a box with an inside dimension of 8x 10 then what do I need to add to get that after it has been cut out.
Using.25 Baltic Birch plywood and .125 EM
Thanks Jeff
sharkcutup
Re: Size of a box
Post by sharkcutup »
.5" (thickness of material x2) to both measurements should get you an 8" x 10" inside measured box using Square Tabs.
I always use a tolerance of .01 but of course that is for my machine
Sharkcutup
Hogan's CNC Crafts
One on One V-Carve Help is Available!!!
PM me for details!
V-Carve Pro 11.003
cusoak
Re: Size of a box
Post by cusoak »
My next question is this I have tried everything I can think of to be able to move the parts around to get them set up so they don't a lot of wood.. When I try to move and rotate the parts the cut line does not move with it.
Jeff
cusoak
Re: Size of a box
Post by cusoak »
Jeff
martindg
Model of CNC Machine: Openbuilds Ox
Re: Size of a box
Post by martindg »
Did you recalculate the tool paths after moving the parts?
sharkcutup
Re: Size of a box
Jeff
I always group the vectors before moving then ungroup them after once satisfied with placement/location I then recalculate toolpaths. By Grouping the Vectors it keeps them all together when moving.
Sharkcutup
Hogan's CNC Crafts
PM me for details!
V-Carve Pro 11.003
cusoak
Re: Size of a box
Post by cusoak »
Thanks for the reply
Jeff
