trying to install a gadget
mikewinters617
Model of CNC Machine: piranha xl
Post by mikewinters617 »
I just upgraded to Vcarve Pro, from desktop, because I wanted the box creator gadget...
turns out I have to install it.
I down load it, and i get a zipped folder.
I unzip the folder, and I can not find any .exe or anything that is an install program.
I go into vcarve pro, and try to install from inside the program, and it sees the folder, and sub folders, but will not let me select anything to upload. (it is looking for *.vgadget
a bit frustrated here.....
Any suggestions?
Thank you in advance...
gkas
Re: trying to install a gadget
Post by gkas »
It's a vgadget, not a zip for V10.5. https://gadgets.vectric.com/V10/box_creator.html. You must have the earlier version.
Which browser are you using? Older versions of Internet Explorer (including the one that loads if you get to the download site via the About Gadgets link on the Gadgets menu) download vgadget files as zip files.
You can either rename it from .zip to .vgadget or download using a modern browser if that is the case.
