Odd Oval Shape
Re: Odd Oval Shape
Post by highpockets »
I think you had tried sooooo many different things that the crv file was just toast :lol:
I copied the Oval vector and Circle vector to a new file. Added the Clipart Rectangle_0.5 and sized to to cover the Oval vector .
Added a Zero Plane
Tilted the Rectangle_0.5 Component and set Combine Mode to Subtract.
Select the Oval vector and Rectangle_0.5 Component, Circular Copy.
The Level Clipping should be the last thing done.
GH 2.zip
(522.1 KiB) Downloaded 11 times
SteveNelson46
Re: Odd Oval Shape
Post by SteveNelson46 »
Use the 30 degree dome from the clipart for the center then import this oval shape, set the properties to merge low and use it to build the project. You can tilt, fade or set the depth as needed. I created a vector around the perimeter of the dome and then offset it 4" to the inside. Then used copy along a vector tool. I have Aspire only so I can't provide a finished example that you can open.
monlover
Model of CNC Machine: Omnitech 4X8 with 8 tool
Re: Odd Oval Shape
Post by monlover »
Hipockets,
I think is is a software glitch
I did follow your directions step by step, No hope, also I did tilting individually but the horizontal shapes was not responding to the tilt as the vertical shapes with the same slop, I did downloaded your file and as you can see at the 3D split screen showing the slop and tilt is not the same at your file, but it looks somehow better than my file.
I guess it is a glitch on the software.
we are Beating a dead horse hear, may be it is not for Vcarve it is for Aspire that can do better at this situation :(
Stevenelson, Thank you for your file but I have VCP 10.507
Thank you.
Re: Odd Oval Shape
Just looked closer at the file I sent you and you are correct some of the Components don't have the same Tilt angle. I don't know why. I'm sending my file to Vectric Support for an explanation.
Stop beating the horse for now...
Re: Odd Oval Shape
Post by mtylerfl »
Hi John,
I haven’t looked at any of the files, but do have a question...did you Bake the original tilted component before using the circular array copy feature?
adze_cnc
Re: Odd Oval Shape
Post by adze_cnc »
Question to original poster: in the original object are the ends of the six inch long slot perpendicular to the face of the disc?
I can imagine this object was created using manual methods and that the oblong areas were cut out with the disc tilted leaving the terminals sloped in relation to the disc's face.
Re: Odd Oval Shape
No Michael I did not :oops:
Re: Odd Oval Shape
OK, Michael came in and saved the Day!
After Tilting the original Rectangle_0.5 Component I forgot to Bake the Component before making the Circular Copy. :oops:
Problem solved. Thanks Michael !!!
Re: Odd Oval Shape
Post by mtylerfl »
Excellent news, John!
Tex_Lawrence
Model of CNC Machine: Shapeoko 3 XXL; V-Carve DT 10.512
Re: Odd Oval Shape
Post by Tex_Lawrence »
Ok, then what is another word for "bake"? Does it mean that something is getting purged in the component and then saved?
Crooked Wood Products - Custom Wood
Truth lies dormant in our future history ― Tex LXIX
monlover
Re: Odd Oval Shape
Post by monlover »
I have tried this Baked option on the past, but for some reason it returns this error now.
sorry for bringing bad news always.
Re: Odd Oval Shape
Think of each of the options (Tilt,Fade, Base Height, Shape Height...) that you can preform on a Component as ingredient of a cake. You mix all the ingredients together to create a "batter" (new component look), then to get the batter to stay together and be a cake you.... Bake it.... Once baked you CAN NOT go back to the original ingredients, it's a cake (baked component)....
Re: Odd Oval Shape
monlover wrote:
Tue Oct 06, 2020 8:57 pm
Remove the Level Clipping.
SteveNelson46
Re: Odd Oval Shape
The file that I provided is a .stl file of the oval component. You should be able to import and use it in VCP.
Re: Odd Oval Shape
Updated crv
GH 2.zip
(299.53 KiB) Downloaded 12 times
