Download 10.5
- Model of CNC Machine: Heiz High Z Machine German manufacture
Download 10.5
I am having a bad day!
II have just downloaded all the files for 10.5
But cannot seem to progress to actually using this upgrade.
What am I doing wrong .. or more to the point, what am I not doing?
Soapy
Soapy
Re: Download 10.5
There's only one file to download to install it. Once it's downloaded double click to launch it and follow the instructions from there.
Re: Download 10.5
I have tried many times to download the file but get this message.
Microsoft Edge says
Aspire_patch_to_v10502.exehttps://storage.googleapis.com/storage.vectric.com/patches/v10_5/Aspire/patches/Aspire_patch_to_v10502.exe
Couldn't download - Network issue Resume
Is your system unable to cope with the download update requests or is it another problem?
Please advise.
Regards,
Mauri.
Microsoft Edge says
Please advise.
Regards,
Mauri.
- Vectric Staff
- Model of CNC Machine: None
Re: Download 10.5
Hi Mauri.
From that error message it looks like you are trying to download the patch directly, when in fact 10.5 requires a new installation. The installation can be found in your V&Co account: https://portal.vectric.com
Adam
Adam
Re: Download 10.5
After countless number of resume presses, I have finally managed to download the 307MB file and then install it.
I am not sure why the system first downloaded the patch file as I am sure I went through the same download procedure as you mentioned in your note.
It now runs finally.
Regards,
Mauri.
Regards,
Mauri.
- Vectric Staff
Re: Download 10.5
Glad you got it sorted Mauri.
Adam
Adam
Re: Download 10.5
Eventually, after a considerable time, I am now using 10.5
I have upgraded my Aspire software many times and I cannot remember ever having had this sort of trouble.
I must have spent an hour.. possibly more, wrestling with this upgrade.
Soapy
Soapy
- Model of CNC Machine: Xcarve
Re: Download 10.5
I too thought it was kind of crazy that I had to download 16 files just to do a simple upgrade.
Re: Download 10.5
What 16 files? It's just the installer file you need.
Re: Download 10.5
Hi Adrian,
When I follow the instructions, there are 16 files marked for download.
So I downloaded them.
Re: Download 10.5
I had exactly the same experience
Piles of files to download so, thinking I was doing the correct thing, I also downloaded them!
Seems to me we both missed some instruction or, more likely, there was insufficient instructions.
Only an hour or two wasted
Soapy
Soapy
