rotary question, probably simple just missing one part
fgirdich
Model of CNC Machine: Legacy Maverick 3x5
Post by fgirdich »
Randall,
looking for some help, your octagon rotary was very useful for a straight taper but now I am trying to make a rounded taper (bullet profile) and I can't seem to get the curve correct. any tips?
Re: rotary question, probably simple just missing one part
Post by TReischl »
What is wrong with the curve? Not being able to see what you are writing about makes it difficult to understand the issue.
Post by Rcnewcomb »
A picture would really help.
Do you want the end of the piece to curve down to a point?
Do want the curve to be smooth, or continue to have the octagon shape?
Multiple profiles with the 2-rail sweep will likely be the solution.
10 fingers in, 10 fingers out
another good day in the shop
fgirdich
Post by fgirdich »
attached .pdf, not sure if it went thru
Post by TReischl »
If you do not see a file when you attach one then we do not see it either.
Post by Rcnewcomb »
Try this: FAQ How do I upload files or photos to the forum?
Note the file size limits.
fgirdich
Post by fgirdich »
uploaded the .jpg file, thanks for the link, could not get the curve of the bullet tip to develop. Maybe try the multiple 2 rail sweeps with smaller steps, i was trying to do it all in one operation
SteveNelson46
Model of CNC Machine: Camaster Stinger/WinCNC
Post by SteveNelson46 »
Something like this? If not, then as said before, we really need a picture.
