Line Bore gadget
Brandon Collins
Model of CNC Machine: felder HO8
Line Bore gadget
Post by Brandon Collins »
Hi All,
Is there a line bore gadget that will do a 32/64/96mm cc line bore for shelves
jimandi5000
Re: Line Bore gadget
Post by jimandi5000 »
Hello Brandon,
Sorry, I just found your post. Can you help me understand your question/request. What is a "line bore for 32/64/96mm cc line bore for shelves" ?
I think I could bang one out something if you can provide so specs.
I am thinking, is this for holes for shelf pins?
Jim
jimandi5000
Hello Brandon,
Jim
Brandon Collins
Hi jim,
yes its for doing shelf pins or Festool MFT tables, handle jig making
Basically the software on my CNC will do it but its clunky takes forever and is not easy to edit.
Also the Array copy tool doesnt work as it works from the space in the middle of the holes where as i need a measurement from the centre to the centre also it to reference an edge or the centre of the board. if you could help this would be great
Brandon
Salmon's lair
Model of CNC Machine: Shopbot PRS Alpha 120-60
Post by Salmon's lair »
jimandi5000 wrote:
Thu May 14, 2020 5:52 am
Hello Brandon,
Jim,
Yes it is for shelf pins, it is also for hinge mounting plates, drawer runners and construction holes..
Just Google 32mm System, will give you a basic understanding of cabinet construction, if you
have any question just ask away.
Paul
Brandon Collins wrote:
Mon Jun 29, 2020 4:25 pm
H
I'm not seeing why the Array Copy tool can't be used here. The diameter of the holes is known and the spacing is known.
Draw one 5mm or 8mm circle and then an array copy with columns (for horizontal) or rows (for vertical) with offset of 32mm.
To do the reference group the line of circles of and use the Move command set to absolute and type the edge offset value.
jimandi5000
Salmon's lair wrote:
Mon Jun 29, 2020 6:30 pm
Hello Brandon,
Jim,
Paul
Hi Paul,
I will write you a gadget today. I will post it ASAP.
Jim
jimandi5000
jimandi5000 wrote:
Tue Jun 30, 2020 4:29 pm
Hello Brandon,
Jim,
Paul
Hi Paul,
Hi Paul,
I have been delayed on writing the Gadget. I have started writing the design requirements and I have some questions on how the gadget should work?
1. Do I draw the panel and holes?
2. Do you want Toolpaths?
3. If Toolpaths, will the holes be drilled or pocketed the 5mm pin holes?
4. Do you want the 8mm construction holes?
5. If Toolpaths for construction holes, will the holes be drilled or pocketed?
Please let me know. :)
Jim
jimandi5000
Hi All,
I have been busy working on a number of items.
Here is a Ver 1.0 of a 32mm gadget tool thing.
It is not done.... but I would like to know if this is the right direction.
Let me know if I should spend more time on on this or not.
Easy32mmSystem.zip
Change the name to Easy32mmSystem.vgadget
(27.1 KiB) Downloaded 45 times
Jim
timothy matthies
Model of CNC Machine: Laguna Smartshop
Post by timothy matthies »
I get an error. "attempt to call a nil value"
