Bad simulation
cusoak
Bad simulation
Post by cusoak »
I have a file here that will not show the simulation of all of the tool paths to cut pockets for finger joints
I have attached the file, could some one look at it and tell me what is wrong
Jeff
Bad simulation.crv
(41 KiB) Downloaded 26 times
Re: Bad simulation
You'll always have issues if the rectangles are the same width as the tool. It's due to internal rounding in the software. You can use a single straight line vector and do a profile cut on the line instead. Alternatively make the rectangles a fraction bigger or "lie" about the tool size by setting it as 0.249" rather than 0.250".
cusoak
Re: Bad simulation
Post by cusoak »
Thanks Adrian as always. I will try th single line vector and see if I can make that work.
What I am trying to do is to be able to cut the tails and pins for finger joints in 1 design and have both boards mounted in front vertically and generate 1 cut file.
would vcarve pro 10 make what I am trying to do any easery.
Jeff
Re: Bad simulation
cusoak wrote: would vcarve pro 10 make what I am trying to do any easery.
No it would be the same in V10.
4DThinker
Re: Bad simulation
Post by 4DThinker »
The disadvantage of cutting finger joints on both boards of a corner at the same time is that it leaves no allowance for a slip fit or room for some glue. I often cut finger joints for my students but by cutting each end separately I can get far more creative with spacing and shape of the fingers. It rarely takes more than one VCarve file as I can usually use the same vectors for both ends with a small change in how the tool path is set up. then save each tool path as a unique file.
Some examples of the variety of joinery possible: http://4dfurniture.blogspot.com/2016/05 ... c-cut.html
4D
