uccnc controller support
- sylvan356
- Model of CNC Machine: CAMaster Stinger 1 w/Rotary, Aspire 10
I am trying to help a friend set up his cnc to be able to use Vectric products. He has an essentially a home built machine using uccnc controller software. I cannot find any post processor for this controller software. When I try to vcarve text the letters are not round but hexagonal. Can anyone help with what post processor he should be using? Thanks.
Re: uccnc controller support
https://forum.vectric.com/viewtopic.php?f=2&t=29343
or
http://www.thecncwoodworker.com/uccnc.html
Scroll to bottom of page
Hope this is of some help
Regards
C
or
Regards
C
- sylvan356
I should also add that if I create a circle vector it cuts fine (not hexagonal). But, if I take the text (the letter O) and convert it to vectors, the machine still cuts it with hexagonal and not round. Perplexing?
- Model of CNC Machine: Gerber System 48,Denford Triac Modified
There was a post about this a while ago, here is the link, if you look towards the bottom you will see that ger21 posted some for UCCNC on his website, the link is included in one of his posts
http://forum.vectric.com/viewtopic.php? ... st#p226983
It's your CV settings in UCCNC, not the post processor.
If you are working in inches, the default CV values are in mm's, and need to be changed. If the error settings are set to .01, try changing them to .003
- sylvan356
Thanks so much for everyone's help. It was a wrong (mm) posting in the CV settings rather than inches. A change and all works like it should!
