V carve what files does it open
Vsantonartino
Model of CNC Machine: Piranha fx
Post by Vsantonartino »
I am new to CNC and for me it has been a challenge. When I go to find files on line I try to down load but I can't import them. What types of files can v carve open.
gkas
Re: V carve what files does it open
Post by gkas »
This link shows all the file import types for all Vectric versions: https://www.vectric.com/products
Post by martin54 »
For me it is generally better importing files rather than trying to open them, how that is done depends on the type of file. Vector, bitmap & 3D files are all handled differently so you need to make sure you are using the correct import option to start with :lol: :lol:
what file formats have you tried downloading & importng??
ger21
Post by ger21 »
Start a NEW file first, then go to File > Import, and you have several options. When you select an option, it will list each file type for that option in the bottom right corner under file types.
ezurick
Post by ezurick »
Vsantonartino wrote:I am new to CNC and for me it has been a challenge. When I go to find files on line I try to down load but I can't import them. What types of files can v carve open.
Actually, that is a pretty broad question. What kind of object are you trying to import? Are they 2D or 3D? Normally when you find CNC object files to import, the person that posted it should tell you what the extension is before you download. A bit more information would help.
