Trouble setting tool pass depth
helensdad
Model of CNC Machine: Oozenest Ox 500 x 750/Openbuilds Minimil
Post by helensdad »
Hi, I am trying to set a pocket tool path to cut some numbers to a depth of 3 mm using a 1/8 ball nose endmill, but I cannot set the path depth, when I tryi in the tool edit box, I enter the number of passes, but they don't show on the main pocket screen. If I click 'calculate' I get the following... 'A formula used in one of the edit boxes is not valid'. I have attached tool set up and edit passes dialog boxes...[img]
[/img]
ger21
Re: Trouble setting tool pass depth
Post by ger21 »
For your cut depth, try using "3" instead of "3mm".
helensdad
Post by helensdad »
Cheers! That worked, many thanks. So simple a solution, I should have spotted that...
scottp55
Post by scottp55 »
Good catch Gerry!
I looked at that for 10 minutes and my eyes skimmed right over that :oops:
Time for second cuppa for SURE :D
OR invest in one of these :D
https://www.youtube.com/watch?v=Z1Q_mXlTfcU
GMH
