box gadget
stevensturgis
Model of CNC Machine: open build
box gadget
Post by stevensturgis »
I would like to know if you can add more than one box at a time to a projects. say 4 boxes at once. also the placement of the box parts are all over the place with a lot of wasted space yet you cant move them. is there a way to make it nest better?
Re: box gadget
If you use the dovetail option you can't nest or move from the original placement as a special toolpath is created. With square tabs you should be able to nest ok.
The intro page for the gadget on the gadget website explains the options available for moving things around.
ElderlyGent
Model of CNC Machine: Piranha FX
Re: box gadget
Post by ElderlyGent »
I am Having the same problem in that my work space is too small to haveall the box parts on it at one time, so I need to be able to ungroup them, the 6 parts, so thatI can cut 2 at a time. say the ends, then the sides ,then the front and back. I tried to find the 'options' as suggested, but just can't see them, so perhaps some kind person with a lot more ability than me will give me some direct directions as to exactly where to find them. This would be a great help probab;y to more than just me and the OP.
Thanks in advance.
EG.
Re: box gadget
Read the section "How to use the box creator?" on the gadget page - http://gadgets.vectric.com/V9/box_creator.html
That explains what options you have if you're using a smaller machine. Basically you have to create the sections one or more at a time as they fit by checking/unchecking the various parts of the box.
