chamfer gadget 1.3 doesn't work in v. 9.012
richard@cnc
Model of CNC Machine: 9015(35,43x59,06 inch) cnc router
Post by richard@cnc »
Hello
today i have installed the new chamfer gadget in Vcarve 9.012.
when i start the app it comes an error message < attempt to call a nil value>
unfortunately, the chamfer gadget still does not work
I also noticed that the gadget files are not installed in the folder `<chamfer> but in the root directory of v9 gadgets
creating a folder manually and copying the files into it also brings no success.
I hope there will be a solution for this
Richard
Re: chamfer gadget 1.3 doesn't work in v. 9.012
The installation path is correct as far as I know. It's only gadgets that have support files or have multiple steps that install into a sub-directory. Simple stand alone ones have always installed in the root folder for the program version in gadgets.
The problem with the nil value is caused by a bit of development code that looks like it's been left in the file by error. If you edit the chamfer.lua file (notepad works fine if you don't have any other editor) and put -- before the line which says require("mobdebug").start() and save the file it will then work.
richard@cnc
Hi Adrian,
You were absolutely right it was due to these 2 lines from the header.
Now it works great :D
Thanks for your support
Richard
