Radius All Corners V9 - Auto Run Compatible
This forum lists all Gadgets that are available now
seanm
Vectric Staff
Model of CNC Machine: 6040 Desktop CNC
Post by seanm »
With the update to V9, the Radius All Corners Gadget has been updated to incorporate some new features,
It is now compatible with our NEW "Auto Run" Feature.
This means the gadget has been redesigned to look more like a normal Vectric tool form and can be set to run automatically with the last used settings without showing the form and also be assigned to a keyboard shortcut for ultimate efficiency.
To find out more information about this and how to make the most out of this gadget, check the link below
http://forum.vectric.com/viewtopic.php? ... 20#p201120
Radius All Corners
Prerequisites:
Must be closed vectors, can process either grouped or non grouped vectors,
Text must be converted to curves before using them with this gadget.
Options include:
Radius Options:
Internal Corners - Radius you want to apply to all the internal corners
External Corners - Radius you want to apply to all the External corners
Vector Options:
Replace Currently Selected? - If selected will delete currently selected vectors whilst creating new ones, else will create new alongside originals.
Layer Options:
Create Vectors on New Layer? - If selected will create radiused vectors on a new layer of the given name, else will create the vectors on the original layer the selected vector was on.
Gadget Run Options:
Run Gadget & Show Form? - This option if checked will display the form as normal upon next opening. If unchecked will run automatically without displaying the options and will use
the previously used settings.
Download Here
http://vectric.eu/gadgets/V9/Vectric/Ra ... rs.vgadget
The Vectric Team
Kayvon
Model of CNC Machine: CNC Shark
Re: Radius All Corners V9 - Auto Run Compatible
Post by Kayvon »
Has the gadget API been changed in v9? I'm still on v8.5 and I understood there was no planned development for increased API capability.
seanm
Vectric Staff
Post by seanm »
Hi Kayvon,
The Gadgets API has been updated to accommodate the new features that came with version 9, we are however in the process of updating the reference manual to include these new features.
It will be updated on the gadgets website as soon as it has been completed.
Thank you for your question,
Sean
RandyGrolemund
Model of CNC Machine: Shapeoko 3 XXL
Post by RandyGrolemund »
I'm using V9 of Vcarve Pro. Here's the error I am getting with the gadget:
seanm
Vectric Staff
Post by seanm »
could you please upload the file you are using to get this error or send direct to me to seanm@vectric.com so i can take a look for you as to what it is that is making it throw up that error?
Thank you
Sean
kstrauss
Model of CNC Machine: Tormach PCNC770
Post by kstrauss »
I installed the round-all-corners gadget and it appears to work as expected. I have been looking at various gadgets to help me to learn how to write LUA programs. However, this gadget does not seem to be in the Gadgets folder. Where is the LUA code?
Gadgets installed from the official gadgets website are installed in the Public Documents\Vectric Files\Gadgets\ folder.
kstrauss
Post by kstrauss »
Found it. Thanks Adrian!
