Using Mach3 as a post processor
jbrunot01
Model of CNC Machine: Pilot Pro
Post by jbrunot01 »
Does anybody know what the difference is between:
M2/3 ATC and M2/3 (no ATC) ??
Getting ready to test my trial version of VC Pro 8.5...
Not sure if I should send the paths to the M3 Post Processor labeled with the "ATC" or not...
Jeff Brunot
Marietta Georgia
dwilli9013
Re: Using Mach3 as a post processor
Post by dwilli9013 »
ATC just denotes Automatic Tool Changer Just pick whichever pertains to your set-up.
D-Dub
Dwayne
Dwilli
jbrunot01
Post by jbrunot01 »
Automatic Tool Changer -
Never-mind... I've discovered what that means now...
I don't have an Automatic Tool Changer, so I wont be selecting that option for my M3 Post Processor.
Thanks fellas
Jeff Brunot
ger21
Post by ger21 »
You don't need an automatic tool changer to use the atc post.
The difference is that the atc post processor adds an M6 tool change command when your g-code uses multiple tools.
Many people have Mach3 stop on the M6 to manually change tools.
Post by martin54 »
As ger21 says you don't need to have an automatic tool changer to use that post processor, it means you can save your toolpaths all to one file & then load them into mach3 as one job rather than each toolpath for each different tool individually.
I don't actually have mach3 set up that way myself but know quite a few people who have. Just one of those things that is on my list of things to do & I never seem to get round to.... one day though.... :lol: :lol:
jbrunot01
Post by jbrunot01 »
Thanks guys. Using M6 to stop the machine while I change the tool seems good.
Jeff
