is this graphic usable for vectors ?
Xxray
Post by Xxray »
Tried and quickly failed with this one, looks like a photo of a tshirt.
Am trying to squeeze this in before xmas for a friend, but am working around the clock and don't think I'll have time to cook one up from scratch.
Have requested better jpg, don't know if one exists ,, Anyone think this is salvageable ?
Doug
mezalick
Re: is this graphic usable for vectors ?
Post by mezalick »
It is,,,are you planing on V-Carving it ?
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
If all you want is a set of vectors based on that I'd just draw it by hand and use a suitable font for the lettering. No need to autotrace something as simple as that.
mezalick
Post by mezalick »
Something like this ???
~M
Michael Mezalick
mm@mezalick.com
Xxray
Post by Xxray »
Well obviously I need to brush up on the basics, never have hand drawn anything.
Not a vcarve, will be a simple profile for an edgelit sign - Thanks Mike, that worked just fine. fonts are skewed but should be able to fix/replace without too much trouble. Am heading off to work, hopefully will be able to make it later this evening and complete next couple days [am working on 3 other things as well], will post back when able.
edit: looks like the whole thing is skewed on closer inspection, inflicted with jaggies.
Any way to smooth them out without mass node editing ?
Doug
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Post by glenninvb »
traced graphic and added text, change if you wish, hope it gets ya started
New xxray.crv
(352 KiB) Downloaded 148 times
mezalick
Post by mezalick »
Xxray wrote:Well obviously I need to brush up on the basics, never have hand drawn anything.
Doug,
It was a very quick example that it could be done..not as an example of top quality work
You just need to practice a bit more and you'll be able to make it yourself.
~M
Michael Mezalick
mm@mezalick.com
IslaWW
Post by IslaWW »
It's like framing a wall. Just cant be done without crowning studs and nailing them to the plates.
No shortcuts
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
Xxray
Post by Xxray »
Doug,
~M
Very true, just crunched for time in the extreme, rarely ever hint for favors.
Thanks for the help though, better than what I would have come up with
glenninvb wrote:traced graphic and added text, change if you wish, hope it gets ya started
More than started, looks ready to cut to me thanks
IslaWW wrote:It's like framing a wall. Just cant be done without crowning studs and nailing them to the plates.
No shortcuts
Yep, no majik juju solution for some things, happens every time this year when I am ultra busy, garage is freezing and everyone wants rush orders to beat the xmas deadline ,,, Have loads of pre made stuff but no good when folks want something custom.personalized
Doug
glenninvb
Post by glenninvb »
mezalick did all the work
just added a couple arcs, circles and lines. Took longer to reply, and I always misspell restaurant (better check :oops: )
don't forget the bar (its only a rectangle :twisted: :) ) and you can find a font more similar to original
Happy Holidays :)
Post by martin54 »
The biggest problem with skills like drawing & node editing are that they take time to learn & when you lead a busy life it always gets pushed to the bottom of the list :lol: :lol:
Auto trace programs have come a long way over the years but there is always something like this that makes them all but useless, guess I was lucky in a way because I really had to learn to do it. When I first started as a signmaker doing cad cut vinyl it was something you really had to learn if you wanted to be able to do any sort of quality work :lol: :lol:
ElevationCreations
Model of CNC Machine: Shapeoko SO3 XXL & SO3
Post by ElevationCreations »
Just another possibility, does the restaurant have any graphics on a website that would be easier to trace?
Xxray
Post by Xxray »
Not that I know of, pretty dinky place from what I understand.
Managed to etch it last night and made the base tonight, both in freezing cold. Will hook up LED's tomorrow and post a pic, should look pretty nice.
Doug
redwood
Model of CNC Machine: Axiom Pro6
Post by redwood »
I had a similar request for a sign. I used a combination of Autotrace and manual work.
Mark
Pioneer, CA
