cutting molding need help
MarkJohnston
Post by MarkJohnston »
I need a comment on whether or not I should cut a relief in the back side of some molding I'm making.
I'm making some 5" wide molding that is suppose to match some 3" existing molding at least for the first 5".
I attached a end view picture of the 3" existing molding and a picture of the 5" molding sample that I'm going to be cutting. The back side of the 3" existing molding has a 1/16" relief cut that's about 1 1/2" long.
So my question is should I cut a 1/16" relief in the back side of the 5" molding? Is it cut to make the molding less resident to twisting or cupping over time?
Thanks for the help.
Mark
MarkJohnston
Re: cutting molding need help
oops I forgot to post the cut sample.
Post by Rcnewcomb »
What material are you using? Hardwood, MDF, foam, etc.
10 fingers in, 10 fingers out
another good day in the shop
MarkJohnston
I'm using Oak to match the other molding. I have to produce 6 pieces 8 foot long.
Mark
rscrawford
Post by rscrawford »
The relief in the back is mostly to help the molding fit better (in case of unevenness or protruding nails along the bottom of the drywall, etc).
Russell Crawford
MarkJohnston
Thanks for the response guys.
I will cut the relief just to be safe.
Mark
