More toy cars
dhellew2
More toy cars
Post by dhellew2 »
Old CAR 2.crv3d
(1.3 MiB) Downloaded 988 times
Old car 1 & 2 fenders 32x5.75x.875.crv3d
(1.96 MiB) Downloaded 968 times
Old car body 1 28.5x5.5x1.25.crv3d
(1.21 MiB) Downloaded 668 times
coupe body.crv3d
(832 KiB) Downloaded 979 times
coupe fenders.crv3d
(284.5 KiB) Downloaded 597 times
Dale
dhellew2
Re: More toy cars
Post by dhellew2 »
1932 plymouth fenders.crv3d
(1.51 MiB) Downloaded 1420 times
1932 plymouth body.crv3d
(717 KiB) Downloaded 553 times
1930 ford coupe new fenders.crv3d
(1.72 MiB) Downloaded 586 times
1930 ford coupe body.crv3d
(693 KiB) Downloaded 551 times
More toy cars
chev coupe fenders.crv3d
(576 KiB) Downloaded 564 times
chev coupe revised 2.crv3d
(326 KiB) Downloaded 571 times
Dale
dhellew2
Re: More toy cars
Post by dhellew2 »
A few photos
Dale
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Re: More toy cars
Post by jimwill2 »
Thank you very much! Good looking toys, I'll play with them one of these days.
Jim Williams
dhellew2
Re: More toy cars
Post by dhellew2 »
I believe these .crv3d files can be saved in V-carve format too. If anyone out there wants them let me know, and which ones. Dale
Dale
zeeway
Re: More toy cars
Post by zeeway »
Well, I went looking for two inch wheels today, and could not find any I liked so...here's one.
Angie
Wheel.crv3d
(339 KiB) Downloaded 480 times
dhellew2
Re: More toy cars
Post by dhellew2 »
Way to go Angie! I'll have to try it myself.
Are you going to draw it up for download?
The ones I used on the cars came from:
http://www.caseyswood.com/shoppingcart/ ... ucts_id=83
I drilled out the holes to 23/64" and used 11/32" axle pegs to eliminate wobble.
Dale
Dale
zeeway
Re: More toy cars
Post by zeeway »
Hi Dale,
Thanks. I posted the file above for download. I checked out Caseys, but I am in kind of a rush (and I like mag wheels).
Angie
bill_w
Model of CNC Machine: PRSalpha BT48
Re: More toy cars
Post by bill_w »
Very nice Angie and thanks for your file
I downloaded it and going to give it a go.
Thanks Bill.
Computers-Yuk....I should junk it...It never does what it should do...only what I tell it.
dhellew2
Re: More toy cars
Post by dhellew2 »
Thanks Angie, somehow I overlooked the file. Dale :oops:
Dale
dhellew2
Re: More toy cars
Post by dhellew2 »
Angie, I suggest using at least a 5/16" axle peg for a 2" wheel. I use 11/32" axle pegs in a 23/64" hole.
A 0.251 hole is a bit tight for a 1/4" axle and if the cars are for kids, a 1/4" axle will break too easy.
The problem with most commercial wheels and axles is wobble i.e. using a 1/4" axle in a 5/16" hole or a 5/16" axle in a 3/8"hole.
A 1/64" clearance (0.0164") is enough if you are using a Tung oil or olive oil finish.
Dale
Dale
zeeway
Re: More toy cars
Post by zeeway »
Thanks, Dale. Adjustment made on my end.
Angie
dhellew2
Re: More toy cars
Post by dhellew2 »
In case anyone missed the old posts, after cutting out the parts I round the edges with a router round-over bit. The model radius corners are designed to fit the router bearing.
It is a good idea to drill a 1/16" hole at the bottom-center of the body into the axle hole to relieve air pressure, and for excess glue squeeze out when inserting the axle pegs.
Make a spacer from a plastic lid to prevent inserting the axle peg in too far. Punch a hole and cut a slit into the hole so you can just pull it out once the wheel is in place. Dale
Dale
ibear
Model of CNC Machine: Homemade from CNCROUTERPARTS PLans
Re: More toy cars
Post by ibear »
Mr. Dale,
just reading through your posts and looking at the cars from the newsletter. Excellent!!
I would be interewsted in any you would be willing to convert to vcarve fromat.
Lee
dhellew2
Re: More toy cars
Post by dhellew2 »
Lee, Look in the v-carve gallery and you will find them already posted. Dale
http://forum.vectric.com/viewtopic.php?f=5&t=18904
Dale
