Commemerative Plate
P.Passuello
Model of CNC Machine: Joe's Hybrid
Commemerative Plate
Post by P.Passuello »
Here is a recent project I did.
The rear of the plate and the 3d model were done in Cut 3D
The Laser engraving and final cutout were done in VCarve Pro
Video of how it was made.
http://www.youtube.com/watch?v=qQ5Cr2b9vDk
Cheers
Peter
The ingenuity of idiots is unlimited.
http://www.youtube.com/user/cncnutz
zeeway
Re: Commemerative Plate
Post by zeeway »
Beautiful work, Peter. Even more importantly, congratulations on the new addition to your family.
Angie
P.Passuello
zeeway wrote:Beautiful work, Peter. Even more importantly, congratulations on the new addition to your family.
Angie
Actually she's my niece, but a wonderful addition to the family none the less.
Cheers
Peter
zeeway
Post by zeeway »
Angie
Cheers
Peter
Even better...you can spoil her, then give her back to her parents...:)
Angie
Len-Tikular
Model of CNC Machine: Home made revision 3
Post by Len-Tikular »
That's nice work Peter. I like your choice of font.
Never heard of a Lasershoe II. I must investigate this.
I'm confused as to how you managed to flip the work over and keep the center aligned. Can you elaborate please. I watched your video but am still unsure.
Keep posting.
Georgie
Len-Tikular (A glider pilots dream cloud)
Aspire v4.0
P.Passuello
Len-Tikular wrote:That's nice work Peter. I like your choice of font.
Keep posting.
Georgie
Hi Georgie,
When I flipped the plate I transfered the center position of the plate from the first side to the 2nd side by measuring. I used the same edges on both sides to ensure I would be right. The cutter was then aligned with the center mark. Normally I would have just drawn lines across opposite corners which would have made things easy and avoided the mistake I made but in my case there was a notch cut out of one corner so I couldn't do this. I like to flip models that are round like the plate because it is easy to get alignment on a circle using the center.
LaserShoe II is a creation of my own so you will only find it on my YouTube channel. Basically it is a method holding the laser while providing a bit of shielding to the user, (Laser glasses still mandatory), and more importantly it provides fume extraction. Drop me a message if you want more info.
Cheers
