3D art from Design and Carve - 1
Discussions and examples relating to the Design & Carve series for Aspire
Moderator: Todd Bailey
Phil
Post by Phil »
I have the Design and Carve 1 collection. Recently I used components from the collection to create the scene attached. When I was working on the scene I found it very convenient to open another instance of Aspire and open the "All Animals" file. With this file open I was able to easily decide which component I wanted. Then I could copy and past the component into my scene.
Now I am wondering if I shouldn't have used the larger components from the collection. Did I loose some resolution by working with the smaller models?
Phil
rej
Model of CNC Machine: 2014 roc-tech 4x8 with servos
Re: 3D art from Design and Carve - 1
Post by rej »
nice job.
please post the result when you carve this.
http://www.3dsigncamp.com
http://www.roctechusacnc.com
dhellew2
Model of CNC Machine: Legacy Artisan 72 and AVID CNC
Post by dhellew2 »
Vector art size does not matter. You can scale them to any size you need without destroying the quality as happens with bitmaps. Dale
Dale
Phil
Post by Phil »
Thanks Dale,
I know that vectors do not get distorted the same as bitmaps when they are enlarged but the 3D components are not vectors. Also I am questioning my process because in the Aspire tutorials it is recommended to create models as large as practical for the application. They say it is not best practice to create a small component and then enlarge it. I'm questioning how the models in the Design and Carve series respond to the way I used them.
Phil
