Can somebody help me know why this is happeneing. I keep getting these rough edges when cutting my file. My vectors are all smooth but when I model it, I get these edges on everything.
Thanks, Oscar
Rough Edges
- AngelicDiablo
- Model of CNC Machine: Shopbot BT48 Standard
- Model of CNC Machine: 2014 roc-tech 4x8 with servos
Re: Rough Edges
do you have it doing a finish pass with an end mill?
http://www.3dsigncamp.com
http://www.roctechusacnc.com
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: Rough Edges
What is your resolution set at? I would set it to very high and remodel it.
Jim Darlas
"Can Do!"
"Can Do!"
- AngelicDiablo
Re: Rough Edges
Finishing pass is with a 1/16 BM @ 8% stepover. Resolution does not matter as I also get it on the finished product. -Oscar
Buckle up... it makes it harder for the aliens to suck you out of your car!
- zeeway
Re: Rough Edges
If you see it in the preview, you will see it on your finished work. Take us through your modeling steps...there is an issue there somewhere.
Angie
Angie
Re: Rough Edges
We are talking Model Resolution here, not screen resolution.Resolution does not matter as I also get it on the finished product
This looks like a Model Resolution issue to me, can you post the file or make it available for download - assuming no copyright issues.
Tim
Re: Rough Edges
It is the vertical wall problem, See also: http://www.vectric.com/forum/viewtopic.php?f=27&t=14370. There is quite abit posted on this issue/problem.
Increase your model resolution to maximum. If you can taper the vertical walls it with also help with the "jaggies". There is also some other workrounds, do a search.
Good Luck
Mike
Good Luck
Mike
Mike E
CuttingandCarving.com
- AngelicDiablo
Re: Rough Edges
Thanks, I'll check out the other posts. It was originally modeled at "Very High". So I'll keep looking for answers.
-Oscar
-Oscar
