Cutting Board...
lpcsales
Cutting Board...
Post by lpcsales »
Well, this forum section hasn't had much going on in it recently, so thought I would give it a bump. I recently did this cutting board with VectorClip3D artwork of the rabbit model. I used a commercial cutting board and machined this into the back side of the board (15" x 12").
After machining, I moved it to my Laser Engraver and engraved the design into the wood around the rabbit carving. I used a .0625 Dia. Tapered bit with a step-over of .0063...took about 3 hrs to carve in the Bot, but I had 'no' finishing work after it was done.
As final touch, I coated it with Canola Oil to bring the luster in the wood back up. The carving was .436" deep and shows good depth and detail.
The flip side of the board is your conventional cutting board. When not in use it can be flipped over and displayed in the kitchen.
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
RoutnAbout
Post by RoutnAbout »
Dave, looks great, nice job!!
________
Don
dighsx
Post by dighsx »
Looks good but man that's one strange looking dog.
Can you tell I'm from the city?
Take it easy.
Jay (www.cncjay.com)
Markm
Post by Markm »
The cutting board looks very nice.
One peice of advice use mineral oil for coating the board next time. Olive, veggie, and other food oils will mold and can make you sick. the mineral oil is ok for constumption (I know I have to give a 1/2 to 1 gal to the cows if they get bloat to work like ex-lax)
I use to always use olive oil untill I heard about this
Mark M
dighsx
Post by dighsx »
Markm wrote: (I know I have to give a 1/2 to 1 gal to the cows if they get bloat to work like ex-lax)
You know there is such a thing as too much information.... hehe
Take it easy.
RoutnAbout
Jay, are you bloated?? to much beer?? I know this guy that can help with that problem ... just in case hehehheh
________
Don
Wemme
Post by Wemme »
Nice Work. I have cut3d but havn't played much with it.
about time i do.
lpcsales
Post by lpcsales »
Thanks All!
Yes, I was aware of the problem with rancid materials. I read that canola oil was ok. I'll have to check more into this. Btw, only the back side was coated with the Canola oil, but I certainly would like to know for sure what would be best used. Definitely wouldn't want to be labeled a terroist..hehe.
BUT...none of this fun would have been possible without our Vectric team!
Dave
Thkoutsidthebox
Post by Thkoutsidthebox »
Very nice. :)
CRFultz
Post by CRFultz »
Dave,
This is what I use....note it can be touched up with mineral oil like Mark stated.
It does a nice job of protecting the wood plus it keeps it nice looking.
http://www.woodturnerscatalog.com/cgi-b ... y=076-0100
Chuck
lpcsales
Post by lpcsales »
Chuck, that's perfect! :D
Thanks a bunch. I'm heading there right now to buy!
Dave
rickw
Post by rickw »
lpcsales
Whatever oil you use on it, i would suggest you do both sides and all edges. Otherwise, it will warp. Plus waterlogged wood dont look good. :)
lpcsales
Post by lpcsales »
Thanks Rick,
I've received my 'Salad Bowl finish' this week and I'll see to it that it is applied to both sides, You're very correct, applying a finish to just one side could be a problem.
Dave
