Here's your sign.
Here's your sign.
My landlord needs new signs. He is moving his automotive repair business into a new building. He has piles of styrofoam he purchased from a roofing company up to 6 inches thick. So I have been planing the foam to thickness with the hot wire and cutting it up. I have to make over 200 characters 10"x1" or 23"x1.5" or 23"x3". He is going to paint the letters and mount them himself and I am glad for that. While I am not a sign maker the Vectric Cut 2D has made this job a snap.
- RoutnAbout
Re: Here's your sign.
Those letters look crisp and sharp. Great Job...
200 pieces should keep you busy for a while!!!
Thank you. Yeah with my small machine it does take a while as I don't like to run it faster than 50 ipm. Corners get rounded if I do. I told him he could probably buy them for less than I can make them but.......he likes me.........and he'll have no cash out as he will credit my rent. I like that.RoutnAbout wrote:Those letters look crisp and sharp. Great Job...
If you are using MACH 3, go into Config-general config, lower right hand corner-positive stop on angle, and enter a degree angle, then you can run faster and not get rounder corners.indycraft wrote:My landlord needs new signs. He is moving his automotive repair business into a new building. He has piles of styrofoam he purchased from a roofing company up to 6 inches thick. So I have been planing the foam to thickness with the hot wire and cutting it up. I have to make over 200 characters 10"x1" or 23"x1.5" or 23"x3". He is going to paint the letters and mount them himself and I am glad for that. While I am not a sign maker the Vectric Cut 2D has made this job a snap.
Thank you for this information. I do use Mach 3 and will check it out.stoneyreef wrote:If you are using MACH 3, go into Config-general config, lower right hand corner-positive stop on angle, and enter a degree angle, then you can run faster and not get rounder corners.indycraft wrote:My landlord needs new signs. He is moving his automotive repair business into a new building. He has piles of styrofoam he purchased from a roofing company up to 6 inches thick. So I have been planing the foam to thickness with the hot wire and cutting it up. I have to make over 200 characters 10"x1" or 23"x1.5" or 23"x3". He is going to paint the letters and mount them himself and I am glad for that. While I am not a sign maker the Vectric Cut 2D has made this job a snap.
I ended up making the entire sign. The frame is 46'7" long and 34" tall. I built the frame in two pieces. We finally got around to mounting it yesterday.
- mikeacg
- Model of CNC Machine: Camaster Stinger, Sidewinder, SB 4x4
You do good work! Thanks for sharing!
Thank you.mikeacg wrote:You do good work! Thanks for sharing!
- metalworkz
Hello,
the sign looks great! Thanks for posting the follow up and picture.
If you are using MACH 3, go into Config-general config, lower right hand corner-positive stop on angle, and enter a degree angle, then you can run faster and not get rounder corners.[/quote]
I did do this this and it is working great. Thank you.
bart
bart
How was the waste material, ie were you using a vac system? Any issues with static charge when cutting the foam?
It was messy. I didn't use my dust shoe...not sure why I didn't. I blew the waste off the machine as I was cutting. The waste was charged and clung if I didn't blow it off.GaryR6 wrote:How was the waste material, ie were you using a vac system? Any issues with static charge when cutting the foam?
I am glad I don't work with foam on a regular basis. This was a one time project.
Bart
