Couple new ones
Couple new ones
Couple of new test runs
- Faux Copper patina with a vector art 3d clip of a sailboat (thanks James your work makes me look good)
1/4" Endmill for roughing, 1/4" Ball Nose for finish, 1/2" vibit for v-carve
Rattle Can Copper, Latex turquose - (550.4 KiB) Downloaded 338 times
- Faux aged and distressed French Country House Plaque
1/4 end mill for roughing 120 degree 1.5 inch v-bit for finish and vcarve
Rattle Can White primer 2lb Shellac sand to distress, shellac with a spit coat. - (497.44 KiB) Downloaded 353 times
- Les_linton
- Model of CNC Machine: ViperX7
- Les_linton
- Paul_n
- Model of CNC Machine: ShopBot PR96
Kimon...
Both samples are great, I really like the copper one, and the materials
you used. Have you looked at the metal coat products from ?
http://www.sculptnouveau.com/
Attached is one that I did using the copper metal coat, and the different
spray on patinas. They also have colored waxes that add great effects.
Paul N
PS... the design was mine, with James Booth doing the great 3D file work for me !!
Paul N
- (46.17 KiB) Downloaded 237 times
