Trying to make some Beard & Hair combs
CrowsWW
Model of CNC Machine: ShopSabre 4896
Post by CrowsWW »
I need some help. I am trying to make some Beard Combs & Hair Combs.
Here is the problem. I would like to have my CNC bevel the combs.so I can save my finger tips from the disc sander.
I have tried two Rail Sweeps, Moulding tool path, Chamfer Tool path. I am at a total lost as how to do this.
I have looked on this forum, tutorials... I have been at this for about 5 hours now and I am brain dead.
So any help will be very much appreciated.
I have Aspire 12.010. I have attached the two comb files.
Hair comb.crv3d
(254.5 KiB) Downloaded 52 times
6.5 beard combo teeth.crv3d
(487 KiB) Downloaded 41 times
Troy Crow
Crow's Woodwork's
Wisdom is the reward for surviving our own stupidity!
-Wendel Volker
Model of CNC Machine: Avid Type| Aspire V12 | Rhino| 3 Bambus
Re: Trying to make some Beard & Hair combs
Post by TReischl »
Are you cutting this with a laser and then basically tapering the the body so the combs get thinner near the edge?
In other words, if you look at it from the end, is it tapered?
I think the folks who use the molding toolpath a lot can help you with this to get the surface of the material tapered, and then you can cut out the comb.
If you are trying to make this like a store bought, injection molded comb, then you are going to need a model and two sided machining. Somehow I do not think that is what you are trying to do?
dealguy11
Post by dealguy11 »
I was wondering the same as Ted. Is it supposed to be double-sided?
As far as getting a taper, it's not too hard. You can use a number of tools to achieve it, but my go-to would be the moulding toolpath. See example attached. I've put the rail and profile into named layers so you can see them more easily. I have the taper going from .3" to .15"
Hair comb.crv3d
(312.5 KiB) Downloaded 44 times
CrowsWW
Post by CrowsWW »
Thanks so much for the help Gentlemen.
Yes I am going to do them as two sided, but I figured if I get it right on one side I then can get the other side also.
I just love this forum! for all of the members that help everyone!
Troy Crow
Crow's Woodwork's
-Wendel Volker
Bobtail Farm
Post by Bobtail Farm »
+1
sharkcutup
Post by sharkcutup »
+1
There are times that I am in Awe of the Experienced and Knowledgeable Members here with their willingness to help those who a New (The Newbies) to the CNC Machining Table and the Vectric Software Products which makes CNC Machining overwhemlingly possible.
Sharkcutup
V-Carve Pro 12.013
CrowsWW
Post by CrowsWW »
I totally agree
Troy Crow
Crow's Woodwork's
-Wendel Volker
