help with first time gadget
smithori
Model of CNC Machine: 3 axis 2021
Post by smithori »
Hi all,
We have been trying to build our first gadget to help us create drilling only for cabinet fronts we receive from outside source
The gadget should import all DXF from a directory one by one. for each file it should move the vectors to a specific location, recalculate all toolpaths, save the nc file, delete all vectors and open a new dxf
at the moment we could not find how to delete all vectors before we import a new dxf, can you please help?
also I am sharing what we wrote so far a would love your comments and improvements
-- VECTRIC LUA SCRIPT
-- Function to display a message box
function MessageBox(title, message)
local mb = wx.wxMessageBox(message, title, wx.wxOK + wx.wxICON_INFORMATION)
end
-- Function to get the selected directory
function GetDirectory()
local openFileDialog = wx.wxDirDialog(nil, "Choose a directory", "", wx.wxDD_DEFAULT_STYLE + wx.wxDD_DIR_MUST_EXIST)
if openFileDialog:ShowModal() == wx.wxID_CANCEL then
return ""
end
return openFileDialog:GetPath()
end
-- Main function
function main()
-- Job Validation --
local job = VectricJob()
if not job.Exists then
DisplayMessageBox("Error: No job loaded")
return false ;
end
--selecting directory
local file_dialog = FileDialog()
file_dialog:FileOpen("","","")
local path = file_dialog.Directory
DisplayMessageBox(path)
--checking for valid directory
local directory = path
if directory == "" then
return
end
--going over selectet folder to map files
local fileList = ""
for file in io.popen("dir \""..directory.."\" /b"):lines() do
fileList = fileList..file
DisplayMessageBox(fileList)
local mr_file = path.. "\\"..fileList
DisplayMessageBox(mr_file)
job:ImportDxfDwg(mr_file)
--selecting vectors
local selection =job.Selection
-------- local selection_index = selection.count
DisplayMessageBox(tostring(selection.Count))
local vocter = Vector2D(50,50)
local trans = TranslationMatrix2D(vocter)
selection:Transform(trans)
local toolpath_mgr = ToolpathManager()
--checking selection on cad objects to retreive size data
local pos = selection:GetTailPosition()
local object
local uid_list = UUID_List()
object, pos = selection:GetPrev(pos)
local bb2d = Box2D(object:GetBoundingBox())
DisplayMessageBox(tostring(bb2d.XLength))
DisplayMessageBox(tostring(bb2d.YLength))
--saving localy the x y values
for i = selection.Count,1,-1 do
uid_list:AddHead(object.RawId)
end
local x_value = tostring(bb2d.XLength)
local y_value = tostring(bb2d.YLength)
local name_is = x_value.. "X".. y_value
DisplayMessageBox(name_is)
toolpath_mgr:RecalculateAllToolpaths()
DisplayMessageBox(tostring(toolpath_mgr.Count))
--add the toolpath to saver
local pos_tool = toolpath_mgr:GetTailPosition()
local toolpath
local tps = ToolpathSaver()
for i=toolpath_mgr.Count,1,-1 do
toolpath, pos_tool = toolpath_mgr:GetNext(pos_tool)
--DO SOMETHING WITH TOOLPATH ....
tps:AddToolpath(toolpath)
end
--saving to nc
local post_pro = tps.DefaultPost
tps:SaveToolpaths(post_pro,directory.. name_is..".nc",false)
fileList = ""
--locating the dxf and saving
--sjob.Selection
-- DisplayMessageBox(tostring(job.Selection))
---clear the used vector
end
return true
end
-- function end
jimandi5000
Re: help with first time gadget
Post by jimandi5000 »
smithori wrote:
Thu May 25, 2023 5:24 am
Hi all,
end
return ""
end
end
-- Main function
function main()
return false ;
end
return
end
local fileList = ""
--selecting vectors
local object
end
local toolpath
end
--saving to nc
fileList = ""
--sjob.Selection
end
return true
end
-- function end
Hi smithori,
Good to hear you are trying your hand at writing your own Gadget. I am sure you can do it and if you need help send me a PM.
I do not think you can Delete Vectors with a gadget.
JimAndi
Jim
Post by adze_cnc »
You might want to enclose code posted here using the code tags (the icon with the </> on it). Quote this message to see what you'd need to type.
Code: Select all
-- sample code
local a = 1
print(a)
Post by adze_cnc »
As well, have you looked at the built-in "DXF Batch Processor" gadget? To locate it from VCarve / Aspire's File menu do:
smithori
Post by smithori »
adze_cnc wrote:
Thu May 25, 2023 9:09 am
Code: Select all
-- sample code
local a = 1
print(a)
Thanks! Will use it next time
Do you know anything on how to delete vectors from a gadget? There must be a way
smithori
Post by smithori »
adze_cnc wrote:
Fri May 26, 2023 10:44 pm
We will look into it, thanks!
gregk
Model of CNC Machine: None
Post by gregk »
For each vector that you want to remove, you need to get a CadLayer object that contains it and then use RemoveObject or RemoveAt method:
Code: Select all
local object = layer:GetAt(pos)
layer:RemoveObject(object)
-- or
layer:RemoveAt(pos)
I hope this helps,
Greg K
