Keyboard Shortcuts and Icons
dighsx
Post by dighsx »
Been working on a cheat sheet that has all the keyboard shortcuts and program icons. Here's what I have so far, take a look and let me know if I missed any shortcuts. Or if there's some other useful information I should put on it.
VCPro_Shortcuts.pdf
(143.09 KiB) Downloaded 673 times
Take it easy.
Jay (www.cncjay.com)
mark296
Re: Keyboard Shortcuts and Icons
Post by mark296 »
dighsx wrote:Been working on a cheat sheet .
Very nice, Thank you.
Paco
Post by Paco »
Good work Jay!
Don't forget:
Node edit mode:
-D (pointing a span) = delete span... while D (pointing at a node) = delete that node.
-P (pointing a node) = make that node the start point... as long as it is one end of a open vector or a node of a closed vector.
dighsx
Post by dighsx »
Thanks Paco, I've updated the sheet.
Take it easy.
Warren
Model of CNC Machine: Router
Post by Warren »
Hi Jay,
Just noticed a couple of mods you need to make on your "Cheat Sheet" and "How to's"
Shortcuts in Drawing Mode.
"S" key does not scale now. "S" is only smooth/unsmooth point.
"P" key does not pan.
I tried to investigate to see if Brian had changed this to another key function, so I first tried Ctrl-P. That didn't work so tried Alt-P and the pan icon appeared.
I thought that was it so I de-selected and tried again.
If you just select Alt-P it doesn't work. You have to do Ctrl-P, then Alt-P. !!
Pressing the "R" key does rotate. But if you are in node edit, placing the pointer over a vector and pressing "R" does not remove that vector. (Mentioned in Custom Form Tools, Step 6.) Now "D" to delete only.
You havn't been finishing off all your Sam Adams and Homebrew Stout while you were compiling these have you? (hehe)
That's all for now, but I must say, you have performed an excellent task.
Cheers,
Warren.
dighsx
Post by dighsx »
Ok Warren made the changes to the cheat sheet and I'll update the how-to and faq stuff too.
Thanks for reviewing this stuff. You start to go cross-eyed trying to find all the combinations of keys in different modes. Maybe I should be drinking while I'm writing these..
Take it easy.
Les_linton
Model of CNC Machine: ViperX7
Post by Les_linton »
Excellent job Jay.
My only comment would be that for those of us that are slightly more "mature" than others.... (I will never admit to getting older) the font on the Shortcut page is a might small.
I printed it off onto a piece of card stock and it makes it pretty handy.
Thanks again,
Les
dighsx
Post by dighsx »
That's funny you say that Les. I made a version for me with the first page landscaped so it's a lot bigger.
VCPro_Shortcuts_LS.pdf
Heres a landscaped version with larger text.
(141.66 KiB) Downloaded 506 times
Take it easy.
Les_linton
:D
Excellent Jay, that sure to the squint out of shortcuts.
Les
Colin P F
Post by Colin P F »
:D Good Work Jay
That is much better, Thanks for putting in the extra work.
Cheers,
Colin
Warren
Post by Warren »
Sorry Jay, :oops:
I said,
I am afraid I got this wrong.
If you press Ctrl-P it does switch you into pan mode. But the pan icon did not appear until I moved the mouse.
Maybe I too should be drinking while I'm writing mine. :)
Burchtree
Post by Burchtree »
Hi Jay
I can’t seem to download the chart, all I get is a small square in the upper left hand corner.
Dan
dighsx
Post by dighsx »
Not a problem Warren, I've updated both files.
Dan, Tony was having problems too. Is anyone else having troubles downloading the files? I'll attach a zip file that contains both cheat sheets. Let me know if you can or can't get this.
VCPro_shortcuts.zip
(209.02 KiB) Downloaded 491 times
Take it easy.
Bill S
Post by Bill S »
Yes Jay,
I have the same problem
Regards
Bill
Bill S
Post by Bill S »
Ok Jay,
I replied before I tried your zip file
Cheers
Bill
