Introduce
As Promised -- The NEW "EASY BOX MAKER GADGET"!!!
It is Finally HERE!!!
It has all the features and box Joint options that the "Easy Tray Maker Gadget" has but with the addition of a LID and with various LID EAR OPTIONS.
On Top No Ears
On Top Front Ear R
On Top Front Ear C
On Top Front Ear L
Recessed No Ears
Recessed Front Ear R
Recessed Front Ear C
Recessed Front Ear L
and MUCH MORE!!!
PLUS
A Feature that the Easy Tray Maker Gadget does NOT include --- a GADGET DEFAULTS RESET Function.
AND
We have even added to the Easy Box Maker Gadget all the necessary Help Buttons and associated Help Details for all Menu Interfaces.
This is Version 1.0
Supports 11.0 and Up
Install
1. Download the gadget EasyBoxMakerVer1.0.zip that is attached to this post.
2. Rename it from EasyBoxMakerVer1.0.zip to EasyBoxMakerVer1.0.vgadget
3. In Vectric Pro or Aspire click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it and click Ok.
It should give you a pop up saying the gadget was installed and you should see EasyDrawerMaker in the Gadgets menu.
Steps for Use:
1. Setup a new drawing with the proper material size
2. Run the EasyDrawerMaker gadget
(The user may want to get into a habit of doing the next two(2) steps after each first opening the gadget.
2a) Click "About" Button.
2B) Click Gadget Reset (the user might want to get into a habit and answer the prompts.
3. Enter the proper values for the drawer opening, clearances, the materials thickness and sizes for the drawer parts
4. Open the Project menu, select where to write the BOMs
5. Open the Milling menu, check the values and select the joint type, bottom type
6. On the Main menu, select the tooling you use to mill the drawer parts
7. Press the OK button.
Rename this Folder to EasyBoxMakerVer1.0.vgadget
Happy Carving Everyone!!!
Be sure to provide us with your comments, thoughts, remarks, etc... It is the only way we can know that we are on the right track in providing you the User a Quality Gadget.
Sharkcutup
(Permission Granted by JimAndi5000 of Jim Andi Gadgets)
