Easy Cabinet Maker
- adze_cnc
Re: Easy Cabinet Maker
I expect the "it doesn't show up" above might be related to this
- sharkcutup
Gosh are we having fun yet?
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- adze_cnc
Hey Jim and Sharkcutup. Some minor errors in EasyCabinetMakerV14.9. Most of the "errors" are initial assignments that are short a parameter or two. This just means the variable will be initialised to "nil" instead of a number or string value (as needed). The only major error is the multiple calls to the function CreateLayerDrillingToolpath(...)
Steven
EasyCabinetBaseVer14.9.xlua
line 38:
should be
line 246:
should be (?)
EasyCabinetDialogVer14.9.xlua
line 585:
The function definition in file EasyCabinetHardwareVer14.9.xlua (line 300) does not accept a parameter.
EasyCabinetToolV14.9.xlua
line 759:
should be
line 1207:
should be (note: line 1203 is right)
EasyCabinetMakerVer14.9.xlua
lines 181, 194, 298, 312, 317, 320, 372, 373, 394, and 398 are all similar so I will only show line 181 below:
In each of the lines noted above the call is providing 6 parameters but the function definition is only set to accept 5 parameters:
Steven
line 38:
Code: Select all
local HoleSpace, HoleCount = 0
Code: Select all
local HoleSpace, HoleCount = 0, 0
Code: Select all
BaseDim.DrawerHeight, AQ = 0.0
Code: Select all
BaseDim.DrawerHeight, AQ = 0.0, 0.0
line 585:
Code: Select all
AddNewGroupWriter(Hardware.Name)
line 759:
Code: Select all
local sThick, sWidth, sLength = ""
Code: Select all
local sThick, sWidth, sLength = "", "", ""
Code: Select all
local Red, Green, Blue = 0
Code: Select all
local Red, Green, Blue = 0, 0, 0
Code: Select all
CreateLayerDrillingToolpath(Milling.LNSideShelfPinDrill .. "-Wall", Milling.Sheet .. "Wall Side Panel Pin Drilling", 0.0, Milling.ShelfPinLen, Milling.ShelfPinLen * 0.25, Milling.ShelfPinLen * 0.35)
Code: Select all
function CreateLayerDrillingToolpath(layer_name, name, start_depth, cut_depth, retract_gap)
- jimandi5000
Thank for looking at this... I am 98% compete with Version 15+ but I will make sure I cover these... I may need to ping you on some of them.adze_cnc wrote: ↑Tue Jan 10, 2023 12:18 amHey Jim and Sharkcutup. Some minor errors in EasyCabinetMakerV14.9. Most of the "errors" are initial assignments that are short a parameter or two. This just means the variable will be initialised to "nil" instead of a number or string value (as needed). The only major error is the multiple calls to the function CreateLayerDrillingToolpath(...)
Steven
line 38:
should beCode: Select all
line 246:Code: Select all
should be (?)Code: Select all
EasyCabinetDialogVer14.9.xluaCode: Select all
line 585:
The function definition in file EasyCabinetHardwareVer14.9.xlua (line 300) does not accept a parameter.Code: Select all
line 759:
line 1207:Code: Select all
should be (note: line 1203 is right)Code: Select all
EasyCabinetMakerVer14.9.xluaCode: Select all
In each of the lines noted above the call is providing 6 parameters but the function definition is only set to accept 5 parameters:Code: Select all
Code: Select all
Jim
Jim
- Model of CNC Machine: Shapeoko 3D XXL
I have a set of base cabinets I want to make using the Easy cabinet maker.
If could send or post here the sizes of the 3 cabinets could some one use the easy cabinet maker to show how they would do all of the steps are done to get it to the point of nesting and cut
Thanks Jeff Peters
Thanks Jeff Peters
- jimandi5000
Hi Jeff,cusoak wrote: ↑Thu Jan 12, 2023 3:11 pmI have a set of base cabinets I want to make using the Easy cabinet maker.
Thanks Jeff Peters
If you will post the details of the cabinet's (height, length, depth, materials, Y/N face-frame, drawers, shelfs, etc.) you want to build. I will make a video for you that shows how I would use the EasyCabinetMaker gadget.
Jim
Jim
Jim
- sharkcutup
+1 Agreed
I can do that too Jim that is if you are too busy with other things. I am here if needed.
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- Model of CNC Machine: LongMill 30x30
Would be good to have a video for this one, lots of things we can mess up when just tinkering with settings.
- sharkcutup
That is why there is a system reset on the About Menu Interface for resetting the gadget back to its default settings.by RickW3DS -- Would be good to have a video for this one, lots of things we can mess up when just tinkering with settings.
But yeah a video would be helpful also!!!
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
Sometimes we just click and go left...
Yep, video would helpusgoobers
- Model of CNC Machine: Avid CNC 5x5 pro
Yes, would love a video on how to use
Can I report an error I found in "The cabinet cut-list" Item ID 100 left side panel...……..width 10 3/4" length 10 3/4
Item ID 110 Right side Panel width 10 3/4 length 18-5/16
The length of item 100 should read 18-5/16
Everything is ok in the drawing.
Great program so much work even the documentation.
- sharkcutup
What Version of the Cabinet Maker created that Cutlist File? Not that it really matters it needs to be rectified/resolved but would be interested in knowing.aa1pi wrote: ↑Thu Feb 02, 2023 1:10 amCan I report an error I found in "The cabinet cut-list" Item ID 100 left side panel...……..width 10 3/4" length 10 3/4
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
The version is 14.9
- adze_cnc
sharkcutup: file EasyCabinetWallVer14.9.xlua
approx. line 442
approx. line 583
In 442 there is duplicate SidePanelWidth
approx. line 442
Code: Select all
CutListfileWriterItem(BOM.PID, "Left Side Panel","Wall", "1",
WallDim.MaterialThickness, BOM.WallCabinetMateralType, BOM.WallCabinetFinish,
WallDim.SidePanelWidth, WallDim.SidePanelWidth)
Code: Select all
CutListfileWriterItem(BOM.PID, "Right Side Panel","Wall", "1",
WallDim.SidePanelWidth, WallDim.SidePanelLength)
