LoadToolpathTemplate with layers missing
MattyZee
Model of CNC Machine: Mechmate
Post by MattyZee »
Hi all,
I have written a custom gadget that does everything I want. My only frustration is a couple of user interactions that I'd like to avoid. The first is when I load a Toolpath Template with layers missing. I'd like to force it to choose "Delete all toolpaths associated with missing layers" without prompting the user. Is that possible? I tried adding the missing layers but leaving them empty, but then the "Recalculate all" fails.
Re: LoadToolpathTemplate with layers missing
The Recalculate All shouldn't fail. It should just give a warning that the toolpath won't calculate as there are no related vectors.
Not everything available in the UI is exposed in LUA, When I come across issues like that I use AutoIt code to automate the interface.
MattyZee
Post by MattyZee »
Thanks Adrian.
You're correct, it doesn't 'fail', but the warning is just as annoying as the 'Missing layers' dialog. Both can be handled with a simple tap of the enter key.
It's a pity there are so many gaps in the Lua API. It could be so much more powerful...
Thanks again for the reply, I'll look into AutoIt....
