Easy Drawer Maker Gadget
Re: Easy Drawer Maker Gadget
This now works flawlessly - thank you for the update!
- sharkcutup
Awesome! Happy to hear that!
Just be sure to let us know if you have any other issues, comments, etc... it is the only way we can provide you the user a usable and reliable Gadget!
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
I'M BACK! I know you're excited Shark - but here's some feedback for you!
First, test cuts in some plywood show the finger joints do very well. I'll probably go down on the dado clearance and up on the finger clearance for next test. Here's a "together" pic that required quite a bit of "persuasion" to get in place. The downside here is that I did two drawers (identical) at the same time. Simply done thanks to changing the "Count" to 2. Unfortunately, I had one set of drawer components come out correctly, but the other drawer the fingers appear to have been placed incorrectly. Unfortunately I didn't notice this inside of Vectric, but had to cut them to find out (doh!). After scratching my head, a quick look at the vectors shows the problem: I haven't had the cycles to see if this was done when just doing one drawer at a time or if it's because I decided to tell the gadget "2" - but I'm suspecting the latter. Let me know if I've somehow missed a setting, but I didn't see anything obvious on my side...
Also, and I'm even hesitate to comment on this again, but if I take the default placement on the sheet and use the "Nesting" feature for best fit, the toolpaths throw the error again regarding bad data. Everything works and recalculates just fine as long as I don't move the sides/fronts on the sheet. Still may be something on my system causing this issue, but thought I'd mention this "variation" of the earlier issue I was experiencing.
- sharkcutup
Okay first issue in Bold above --sundown wrote: ↑Fri Oct 21, 2022 12:40 amI'M BACK! I know you're excited Shark - but here's some feedback for you!
I have looked at this and you are correct in that the FINGERS on the Right Side Part moves for multiple parts. As I am NEW to coding I have brought this up to Jim5000 of Jim Andi Gadgets so we should have this fixed soon! In the meantime Copy/Paste the Correct Side Part as many times as you wish then don't forget to re-Calculate Toolpaths.
Second issue Italicized above ---
I have never played around with using Nesting after the gadget so I have not seen the issue you are referring to. But I can manually move the parts around on any given sheet and re-calculate with no issues.
Thank you for Bringing these issues to our attention! We will fix what can be fixed and monitor those where there may be an issue. Without your and other forum members issues/comments/remarks etc... we would not be able to produce a quality usable gadget.
Thank You,
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- jimandi5000
- sharkcutup
Hello All,
1.) Fixed the Right Side Moving Fingers when selecting Multiple Drawers.
This Version 4.5
Supports: 10.5 and up
Install
1. Download the gadget EasyDrawerMaker.zip that is attached to this post.
2. Rename it from EasyDrawerMaker_4.5.zip to EasyDrawerMaker.vgadget
3. In Vectric Pro or Aspire click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it and click Ok.
It should give you a pop up saying the gadget was installed and you should see EasyDrawerMaker in the Gadgets menu.
Steps for Use:
1. Setup a new drawing with the proper material size
2. Run the EasyDrawerMaker gadget
3. Enter the proper values for the drawer opening, clearances, the materials thickness and sizes for the drawer parts
4. Open the Project menu, select where to write the BOMs
5. Open the Milling menu, check the values and select the joint type
6. On the Main menu, select the tooling you use to mill the drawer parts
7. Press the OK button
Rename this Folder to EasyDrawerMaker_4.5.vgadget
To Work on NEXT:
As mentioned in earlier post adding a Bottom Styling Option (similar to the Tray Maker Gadget). Captive Bottom, Rabbeted Bottom, and Flat Bottom.
Happy Carving!!!
Sharkcutup
(Permission Granted by jim5000 of Jim Andi Gadgets)
This Version 4.5
Install
Steps for Use:
To Work on NEXT:
Happy Carving!!!
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
Shark -
Immediately following the setup dialog I receive the following error message. The error message doesn't give me a whole lot to go on, so I'm unsure how to proceed. I attempted to change the save path just in case there was some type of permissions issue at the file system level, but no luck. Any thoughts?
- sharkcutup
Works Fine Here!
I even downloaded it from the forum and installed it into V-Carve Pro 11.0. Setup tools, path , etc... and ran it for 2 Drawers. A Total Fresh Install and it worked as expected. So I would have to say something fishy is going on on your end.
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- jimandi5000
You may have a program that has a file open or had a file open in the location. the Operating System has blocked the write function. Check and see if any app is open (notepad, file explorer, etc..) close them and try again. I will work with SharkCutUp to add a error trap for this issue and it will be in the next gadget release.sundown wrote: ↑Sat Oct 22, 2022 1:30 pmShark -
Jim
Jim
- Model of CNC Machine: Alpha CNC 6090 with 4th Axis
Hi all,
This will be one of those "obvious when you know" things.
Can someone please tell me how to uninstall gadgets.
I have Easy drawer maker 4.3 & 4.4
I want to install 4.5 but I want to remove the other two first.
I have looked but can't see a way to do it.
I expect it's right under my nose.
Thanks.
Jim
Thanks.
Jim
- jimandi5000
Hello Jim,
This is Jim (AKA JimAndI)
It is easy to remove or uninstall a gadgets from your system.
Step one: Open up File Explorer and navigate to this location:
C:\Users\Public\Documents\Vectric Files\Gadgets
You'll see versions of the Vectric software listed (here is a list of my directory) Now navigate down into the version and into be particular Gadget you wish to remove and just delete it. I do recommend making a backup copy to another location before deleting any files. In case you delete the wrong one, you can copy it back from your backup location.
Let us know if you have any issue.
Jim
Jim
- sharkcutup
Easy Drawer Maker Gadget with New Features ---- COMING SOON!!!
Jimandi5000 and I have been working feverously on adding BOTTOM STYLE OPTIONS (Captured Bottom, Rabbet Bottom, or Flat on Bottom) for the Bottom Dadoes in the four parts (Sides(2), Front and Back).
Be on the lookout for this Awesome Gadget!!! COMING SOON!!!
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- sharkcutup
As Promised Here it is The New and Improved "EASY DRAWER MAKER GADGET"
Items Added:
Bottom Styling - Captive, Rabbet, and Flat Bottom
Applicable Settings that turn on/off when choosing Joint and/or Bottom Styling
Gadget/System Reset of All DEFAULT SETTINGS whether the Job Setup is in Metric or Imperial Standard
NO longer REQUIRED to RESTART gadget upon Gadget/System Reset
Tooling application Error Trapping
Documentation to include all the aforementioned above added items
and a few other Minor additions/fixes
We also added:
1.) menu labels now have popup tool tips
2.) smarter menus based on style selection
3.) error trapping with clean error messaging
This is Version 5.2
Supports 11.0 and Up
Install
1. Download the gadget EasyDrawerMakerVer5.2.zip that is attached to this post.
2. Rename it from EasyDrawerMakerVer5.2.zip to EasyDrawerMakerVer5.2.vgadget
Steps for Use:
5. Open the Milling menu, check the values and select the joint type, bottom type
Rename this Folder to EasyDrawerMakerVer5.2.vgadget
To Work on Next : More Joint Styles
Happy Carving Everyone!!!
Be sure to provide us with your comments, thoughts, remarks, etc... It is the only way we can know that we are on the right track in providing you the User a Quality Gadget.
Sharkcutup
(Permission Granted by JimAndi5000 of Jim Andi Gadgets)
Items Added:
We also added:
This is Version 5.2
Install
Steps for Use:
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- sharkcutup
Here are two of the Bottom Styles Shown here in Model Form which have been added to the Easy Drawer Maker Gadget
Captured Bottom
Rabbeted Bottom
Sharkcutup
Captured Bottom
Rabbeted Bottom
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- sharkcutup
Items Added:
HELP Function Buttons with Documentation/Instructions to All User Menus.
Created a 15 Minute Video Demonstration of the Easy Drawer Maker Gadget at YouTube.com Visit the Sharkcutup CNC Channel.
and a Few Other Minor Fixes.
This is Version 5.3
Install
1. Download the gadget EasyDrawerMakerVer5.3.zip that is attached to this post.
2. Rename it from EasyDrawerMakerVer5.3.zip to EasyDrawerMakerVer5.3.vgadget
Steps for Use:
1. Setup a new drawing with the proper material size (A Good Start - 24.0" by 24.0" by 0.5")
Rename this Folder to EasyDrawerMakerVer5.3.vgadget
Sharkcutup
Items Added:
This is Version 5.3
Install
Steps for Use:
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
