Bit question
Mike
Bit question
Post by Mike »
I just purchased Photocarve. Let me be the first to say, I have a lot to learn. Just wondering which bits you would recommend for carving in wood and possibly for lithophanes.
lovebugjunkie
Model of CNC Machine: Romaxx HS1
Post by lovebugjunkie »
A couple of links for you to try, also search on lithophane will get you some more.
http://vectric.com/forum/viewtopic.php?t=2718
http://vectric.com/forum/viewtopic.php?t=2937
crocky
Post by crocky »
Hi Mike,
I use a 30 degree vee bit for lithophanes, single flute and it does the full cut in single pass.
I use a emeditor to remove the reduntant Z clearance moves and that saves a lot of time too :)
Cheers,
Bob
Aspire, VCarve Pro, PhotoVCarve
Blog: http://www.ocm.com.au/wordpress/
holland1vt
Re: Bit question
Post by holland1vt »
Hi Crocky
You mentioned an editor called Emeditor.
Where can I get the software.
Also, when I finish the carvings in wood do I need to apply
stain to make the image visible as I cannot make out the image
after carving.
Ed
CRFultz
Re: Bit question
Post by CRFultz »
holland1vt wrote:Hi Crocky
after carving.
Ed
Ed there are many different variations on finishing. Most I believe would use stain. If you choose to go that route you can brush it on and dab the excess of with a cloth, lightly sand with a sanding block and then use a steel brush to clean the veins out.
I like to wax the blank before I cut it then use spray paint and then a couple of runs thru the drum sander, clean with a brush and seal.
You will need to try the different methods discussed here to find the one you like the most. The basic goal is to have light and dark separation.
holland1vt
Re: Bit question
Thanks Crockey
I will definetely try your suggestions and get back to you.
About the Emediter,Where do I get the software.
Ed
bluefincnc
Re: Bit question
Post by bluefincnc »
I have no idea what Emediter is, but I read here somewhere (or maybe it was CNCZone) that someone used Microsoft Word or Excel to do a "find and replace" function, so you would find all Z .250's and replace with Z whatever you want, BUT you need to have your first and last .250 safe moves in place otherwise..................... :shock:
holland1vt
Re: Bit question
Thanks bluefincnc
Ed
Greasetattoo
Re: Bit question
Post by Greasetattoo »
http://www.emeditor.com/
Never used it, but here is the link..
I just googled it! :shock:
mboydraska
Model of CNC Machine: 3 axis homebuilt
Re: Bit question
Post by mboydraska »
Notepad or wordpad will find replace. These are standard on most computers.
HAPPY CUTTING
Mike
