First Photo VCarve
A6ETramMN
Model of CNC Machine: OneFinity Woodworker
First Photo VCarve
Post by A6ETramMN »
This is my first attempt at a Photo VCarve using VCarve Pro 11. I used maple, a 60 degree VBit, 100% line spacing, 45 degree raster and max depth of .05 inches. I flattened the board with a spoilboard bit, then sanded it to 320 grit before carving. After the board was done I sprayed 2 coats of lacquer and let dry overnight before spray painting the black. I let that dry for 24 hours before sanding the spray paint with 150 grit to bring out the picture. I was quite surprised it worked the first time.
If at first you don’t succeed, you’re about average.
Re: First Photo VCarve
Post by mtylerfl »
Beautiful job!
A6ETramMN
Post by A6ETramMN »
mtylerfl wrote:
Fri Feb 04, 2022 10:49 pm
Beautiful job!
Thanks. Next time I’ll VCarve an ellipse around the outside of the oval cropped picture to make a clean line.
StrataBoy
Model of CNC Machine: OneFinity Woodworker X-50
Post by StrataBoy »
Is there a training video on how to do this? I did a search on the Vectric web site but didn't find anything.
Thank you!
Rex
Holzarbeiter
Model of CNC Machine: Camaster Stinger SR24
Post by Holzarbeiter »
Dang, that is a great looking photo carve for a 1st try! I cant wait to see your "improvements". Well done!
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
A6ETramMN
Post by A6ETramMN »
StrataBoy wrote:
Sat Feb 12, 2022 5:01 am
Thank you!
Rex
There are videos but most of the time I wing it :) The one thing I found that was important was to flatten the piece before you start carving the photo. Some of the cuts are shallow and if your board is not flat the shallow cuts will be air. It’s happened to me on a couple of VCarve cribbage boards.
Craig
StrataBoy
Post by StrataBoy »
Thank you!
Luvtocarve
Model of CNC Machine: Next Wave Piranha XL
Post by Luvtocarve »
Don’t you just love it when a project turns out this nice? Well done!
Steve Harp
Wadsworth, Ohio USA
www.trlw.us
