Code: Select all
if VERSION < 10 then
Code: Select all
Code: Select all
g_toolpath_type = registry:GetString("ToolpathType", g_toolpath_type)
Yes, restoring this line didn't through up any errors and all worked fine.adze_cnc wrote: ↑Tue Jun 07, 2022 3:54 pmI am reasonably confident that you can restore the line:Code: Select all
That would be nice.
Code: Select all
-- table.sort( tp, function(a, b) return a[t_toolpath_number] > b[t_toolpath_number] end )
Unfortunately that's how the Vectric software creates them. Which is understandable if you are only creating one as happens when you use the builtin Aspire/VCarve "V-Carve / Engraving Toolpath".
