Hello All,
My newest Gadget, it is the Easy Organizer Maker gadget. It creates a organizer from the user entering the number of Rows and Columns. The Organizer is made up of 2 sides, 2 ends, one bottom, and the correct Dividers and Columns. The sides, bottom, dividers, columns and ends can have different thickness material. The gadget supports 3 types of bottom construction styles. It also supports the Dog Bone, Blind Dog Bone, T-Bone Joint, Blind T-Bone, Sniglet Joint and the Blind Sniglet joints. It also creates 3 BOM file types.
This Version 1.5
Supports: 11.0 and up
Install
1. Download the gadget EasyOrganizerMaker.zip that is attached to this post.
2. Rename it from EasyTrayMaker.zip to EasyOrganizerMaker.vgadget
3. In Vectric Pro or Aspire click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it and click Ok.
It should give you a pop up saying the gadget was installed and you should see EasyOrganizerMaker in the Gadgets menu.
Steps for Use:
1. Setup a new drawing with the proper material size
2. Run the EasyOrganizerMaker gadget
3. Enter the proper values for the Organizer overall size and the materials thickness for the Organizer parts
4. Open the Project menu, select where to write the Organizer BOMs
5. Open the Milling menu, check the values and select the joint type
6. On the Main menu, select the tooling you use to mill the drawer parts
7. Press the OK button
If you have any issues or questions let me know.
- jimandi5000
- EasyOrganizerMaker.zip
- Rename to: EasyOrganizerMaker.vgadget
- (39.41 KiB) Downloaded 178 times
Jim
Jim
- sharkcutup
Re: Easy Organizer Maker gadget
Be sure to create Proper Material size and that it is TWO_SIDED for there is a material sheet created that is a two-sided carving. You will find out very quickly though that there is an error pop-up message that will appear when trying to start the gadget if you don't have the project setup as TWO_SIDED drawing.
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- jimandi5000
Hello All,
I have updated the code to address the endless error trapping loop on attempting to clear a preselected tool issue. The solution will allow you to select tools for the Dado or Finger clearing path that are of the same bit diameter or smaller than the primary tool. You will be presented a message box (see below) and the solution will step over the issue and produce the drawing and toolpaths correctly.
Additional error trapping has been added and the optimization of code.
This Version 1.5
Installation Instructions
2. Rename it from EasyOrganizerMaker.zip to EasyOrganizerMaker.vgadget
Will be presented a pop message up saying the gadget was installed and you should see the new version of EasyOrganizerMaker in the Gadgets menu.
This Version 1.5
- (39.96 KiB) Downloaded 145 times
Jim
Jim
- Model of CNC Machine: EZ Route 4x8/WinCNC
Do you have a how to vide? My biggest problem with the gadgets is my lack of knowledge. I need definitions for the terms and the selection options.
Thanks as always for what you do.
Willy
Willy
- sharkcutup
Here is a link to a video on the Easy Organizer Gadget ---
Click "watch on Youtube" or the Arrow in the Lower Right.
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
