Has anyone seen WoodSmiths video of Joinery?
He show a great way of making Box Joints with a TBone but Blind ones. From minute 7 onwards
You think the Gadget could do such things??
This means, the Joint is Hidden from the inside and the Outside view, but fully doable with the CNC working horizontally.
Benjamin
Easy BoxJoint Maker 3.2
- BenjaminwithCNC
- Model of CNC Machine: Danibrum 1325 ATC Rotary 4x1
- jimandi5000
Re: Easy BoxJoint Maker 3.2
Hi Benjamin,
This is the same joint I use on the EasyDrawerMaker gadget.
I could make a box gadget with these joints but I was thinking it is already out there.
Jim
Jim
- jimandi5000
After reviewing my gadget, I was wrong. The EasyDrawerMaker gadget only creates the TBone joint and does not create the "Blind" TBone. I can add it as an option if you think it should be.jimandi5000 wrote: ↑Fri Mar 04, 2022 6:06 pmHi Benjamin,
What are your thoughts?
Jim
Jim
- jimandi5000
- BenjaminwithCNC
I see what you did there!
Yes that would be, what i thought about. For Drawers and Boxes.
Benjamin
Benjamin
